![](/wcc-assets/document/images/485/c04268497.gif)
HP ProDesk 600 G1 Desktop Mini PC is HP’s smallest business desktop yet. Efficiently crafted to save space and energy.
Feature
Intel Q85 express
Processor
Graphics
Intel HD graphics on all models (integrated on processor)
Adapters and cables
Storage
Networing/Communications
Audio/Multimedia
Audio:
Keyboards and pointing devices
Security
Specification
Form factor
MXM 3.0
Graphics controller
AMD Radeon HD 7650A
Core clock
600 MHz
Memory clock
800 MHz
Memory
2GB, DDR3, 128-bit wide
Bus type
MXM
Maximum power
35 W
Power source support
12 V and 19 V
3D API support
DX11, SMS
HDCP support
Yes
Display maximum resolution
Supported graphics APIs
DX11, OpenGL, full 1080p BD (H264) playback in hardware, Multi-Stream DisplayPort
support
Specification
Form factor
Low profile: 2.713 × 6.15 in
Graphics controller
NVIDIA NVS 310
Memory clock
875MHz
Memory size
512MB DDR3
Memory bandwidth
14GB/s
Maximum power
19.5 W
Up to 2560 x 1600 (digital display) per display
Specification
Form factor
PCIe x16 card
Graphics controller
NVIDIA Kepler Architecture GPU
Core clock
875 MHz
Memory clock
891 MHz
Memory size
2GB DDR3 128 bit
Memory bandwidth
28.5GB/s
2560 x 1600 digital, 2048 x 1536 analog
Display output
Integrated 400 MHz RAMDAC
Specification
Form factor
Graphics controller
NVIDIA NVS 315
Memory clock
875MHz
Memory size
512MB DDR3
Memory bandwidth
14GB/s
Connectors
Display output
Specification
Form factor
PCie x16
Graphics controller
AMD radeon HD 8350
Core clock
GPU engine operates at 523 MHz
Memory
1GB, DDR3, SDRAM
Memory clock
875 MHz
HDCP support
Yes
Specification
Form factor
PCie x16
Graphics controller
AMD Radeon HD 8490
Core clock
GPU engine operates at 875 MHz
Memory
1GB, DDR3, SDRAM
Memory clock
900 MHz
HDCP support
Yes
Specification
Capacity
500,107,862,016 bytes
Rotational speed
7,200 rpm
Drive type
Self-Encrypting Drive (SED) with SATA interface
Interface
SATA Interface conforming to Serial ATA International Organization: Serial ATA Revision 2.6
Segmented buffer with write
cache
32768KB - A portion of buffer capacity used for firmware
Number of sectors
976,773,168
Single track: 1.0 ms
Seek time (typical reads)
Average: 13 ms
Full-stroke: 25 ms
Media diameter
63.5 mm/2.5 in
Height
6.8 mm, ±0.2 mm/0.267 in
Width
69.85 mm, ±0.25 mm/2.75 in
Length
100.2 mm, ±0.25 mm/3.945 in
3.35 oz/95 g (max)
Operating temperature
0° to 60°C (32° to 140°F)
Specification
Formatted capacity
1TB
Spindle speed
5,400 rpm +/- 0.2%
Drive type
Solid State Hybrid Drive (SSHD) technology with NAND flash
Interface
Serial ATA (SATA)
Cache buffer
64MB
NAND flash commercial
Multilevel Cell (cMLC)
8GB
Number of sectors
976,773,168
Single track: 2.0 ms
Average: 12 ms
Height
9.5 +/- 0.2 mm (0.374 +/-.008 in)
Width
69.85 +/- 0.25 mm (2.750 +/- 0.010 in)
Length
100.35 +0.20 / -0.25 mm (3.951 +0.008 / -0.010 in)
115 g/0.254 lb (max)
Specification
Formatted capacity
500GB
Spindle speed
5,400 rpm +/- 0.2%
Drive type
Interface
Serial ATA (SATA)
Cache buffer
64MB
NAND Flash Commercial
8GB
Number of sectors
976,773,168
Average: 12 ms
Height
6.8 +/- 0.2 mm (0.268 +/-.008 in)
Width
Length
95 g/ 0.209 lb (max)
Operating Temperature
Specification
Unformatted capacity
120GB
Architecture
Multi Level Cell (MLC) NAND Flash with wear leveling 10 channel controller
Interface
Serial ATA 2.0 (3.0 Gb/s)
Dimensions (W x H x D)
6.98 x 0.95 x 10.2 cm (2.74 x 0.37 x 4 in)
80 g (0.18 lb)
Bandwidth performance
Latency
Power
Useful drive life
35TB written, up to 20GB/day for 5 years
Environmental
(all conditions, noncondensing)
Specification
128GB
Architecture
Interface
SATA 6 GB/sec
6.985 x 0.7 x 10.05 cm (2.75 x 0.276 x 3.96 in)
73 g (0.16 lb)
Latency
Power
Useful drive life
1.2 million device hrs
Environmental
Regulations
UL, CSA, EN 60950-2000, CISPR Pub 22 Class B, CNS 13438, AS/NZS
CISPR 22:2002 Class B, Korea KCC, CE Mark
Specification
160GB
Architecture
Interface
SATA 3GB/sec
80 g (0.18 lb)
Latency
Power
Useful drive life
Environmental
Regulations
UL, CSA, EN 60950-2000, CISPR Pub 22 Class B, CNS 13438, AS/NZS CISPR 22:2002
Specification
256,186,209,271 bytes
Architecture
Self-Encrypting (SED) Solid State Drive with 25nm MLC NAND Flash and SATA interface
Interface
NAND flash
25nm MLC NAND flash
Height
.275 in/7 mm
Width
2.75 in/69.85 mm
Length
3.95 in/100.5 mm
73 g (0.161 lb)
Latency
Power
SATA power consumption: 160 mW (active average); <85 mW (idle average)
Useful drive life
72TB written, up to 40GB/day for 5 years
Environmental
Specification
Capacity
Rotational speed
7,200 rpm
Interface
Serial ATA 3.0 (6.0 Gb/s)
Buffer size
16MB
Logical blocks
976,773,168
Seek time (typical reads,
includes controller overhead,
including settling)
Height (nominal)
1 in/2.54 cm
Width (nominal)
41° to 131°F (5° to 55°C)
Specification
Capacity
1,000,204,886,016 bytes
Rotational speed
7,200 rpm
Interface
Buffer size
32MB
Logical blocks
1,953,525,168
including settling)
Height (nominal)
1 in/2.54 cm
Width (nominal)
5° to 55°C (41° to 131°F)
Specification
2TB
Rotational speed
7,200 rpm
Interface
SATA 6Gb/s NCQ
Cache, Multisegmented
64MB
Seek time (average)
Height
1.028 in/26.11 mm
Width
4.0 in/101.6 mm
Depth
5.787 in/146.99 mm
1.38 lb/626 g
Specification
Height
12.7 mm height
Orientation
Either horizontal or vertical
Interface type
SATA/ATAPI
Disc recording capacity
Up to 8.5GB DL or 4.7GB standard
128 x 12.7 x 127 mm (5.04 x 0.5 x 5.0 in) without bezel
Specification
Height
12.7 mm slim tray-load
Orientation
Interface type
SATA/ATAPI
Disc capacity
Up to 128GB QL, 100GB TL, 50 GB DL or 25GB standard SL
Dimensions
W x H x D (maximum)
Specification
Height
12.7 mm
Orientation
Interface type
SATA/ATAPI
Weight (maximum)
Up to 0.37 lb (170 g) without bezel
Specification
Connector
RJ-45
System interface
Integrated on PCA
Controller
Intel I217LM GbE platform LAN connect networking controller
Memory
24 KB FIFO packet buffer memory
Data rates supported
10/100/1000 Mb/s
IEEE compliance
Bus architecture
PCI Express and SMBus
Data transfer mode
PCIe-based interface for active state operation (S0 state) and SMBus for host and
management traffic (Sx low power state)
Power requirement
Boot ROM support
Yes
Network transfer mode
Network transfer rate
Environmental
Management
WOL, auto MDI crossover, PXE, Muti-port teaming, RSS, Advanced cable diagnostic
Alerting
ASF 2.0 support; AMT 9.0 support
Specification
Connector
RJ-45
System interface
PCI express x1
Controller
Intel I210 gigabit ethernet controller
Memory
Integrated Dual 48K configurable transmit receive FIFO buffers
10/100/1000 Mb/s
IEEE compliance
Bus architecture
PCI-E 2.1
Data path width
X1, 250 MB/s, Bi-directional interface
Data transfer mode
Bus-master DMA
Hardware certifications
FCC, B, CE, TUV-c, TUVus Mark Canada and United States, TUV-GS Mark for european
union
Power requirement
Aux 3.3 V, 3.0 W in 1000 base-T and 1.0 W in 100 Base-T
Boot ROM support
Yes
Environmental
Management
WOL, PXE, DMI, WFM 2.0
Specification
Type
Integrated
HD stereo codec
Realtek 2-channel ALC221 codec
Audio I/O ports
Front microphone-In (150-K ohm Input Impedance)
Internal speaker amplifier
1.5 W amplifier for the internal speaker only. External speakers must be powered externally.
Rear Line-in audio port is re-taskable as either Line-in or Microphone-In.
Multi-streaming capable
Multi-streaming can be enabled in the Realtek control panel to allow independent audio
streams to be sent to/from the front and rear jacks.
Sampling
8 kHz - 192 kHz
Wavetable syntheses
Yes – Uses OS soft wavetable
Analog audio
Yes
Number of channels on Line-Out
Stereo (Left & Right channels)
Internal speaker
Yes
External speaker jack
Yes
Full Duplex
Yes
Specification
Standard efficiency
65 W active PFC
87% efficient
Operating voltage
range
90 - 264 VAC
Rated voltage range
100 - 240 VAC
Rated line frequency
50/60 Hz
Operating line
frequency range
47 - 63 Hz
Current leakage
(NFPA 99)
< 250 μA
Dimensions
55 x 30 x 113.5 mm (2.2 x 1.2 x 4.5 in)
Total cord length
8 in (12 ft)
Specification
Chassis (W x H x D)
175 x 34 x 177 mm (6.9 x 1.3 x 7.0 in)
System volume
62.79 cu in
1.05 L
System weight
2.9 lb
Stand dimensions
Packaging
198 x 290 x 500 mm (7.8 x 11.4 x 19.7 in)
Shipping weight
4.1 kg (9.0 lb)
Palletization profile
Feature
Operating systems (Preinstalled)
Specification
Temperature range
Relative humidity
Maximum altitude
(unpressurized)
Specification
Eco-label
certifications
& declarations
