Precise alignment between printheads is essential for accurate colors, smooth color transitions and sharp edges in graphical elements. Your printer has an automatic printhead alignment process which runs whenever a printhead has been accessed or replaced.
In cases where the paper has jammed or you are experiencing problems with color accuracy, see Color managementColor management; you may need to align the printheads.
note:If the paper has jammed, it is recommended that you reinsert the printheads and initiate the realignment procedure by pressing , then , then Image Quality Maintenance > Align printheads.
caution:Do not use transparent or semi-transparent paper to align the printheads.
