Printer Specifications for HP LaserJet 1020 Printer Series
This document is for HP LaserJet 1020 series printers.
HP LaserJet 1020 Model
Figure : HP LaserJet 1020 printer
Illustration of the product.
Printer model
Part number
Q5911A
System requirements
Feature
Minimum system requirements
Windows Vista, 7, 8, 10
Processor
1 GHz 32-bit (x86) or 64-bit (x64) processor
RAM
1 GB (32-bit) or 2 GB (64-bit)
Free disk space
2 GB
Connectivity
Hi-Speed 2.0 USB port
Browser
Internet Explorer, Firefox, Google Chrome
Windows XP
Processor
Pentium 233 MHz processor
RAM
128 MB
Free disk space
150 MB
CD ROM drive
Required
Connectivity
Browser
Internet Explorer 6.0
Windows 2000
Processor
Pentium 166 MHz processor
RAM
64 MB
Free disk space
150 MB
CD ROM drive
Required
Connectivity
Browser
Physical dimensions
Dimension
Measurement
Height
209 mm (8.2 inches)
Width
370 mm (14.6 inches)
Depth
242 mm (9.5 inches)
Weight (2,000-page cartridge installed)
5.9 kg (13.0 lb)
Print Cartridges
Color
Print cartridge number
Black
Q2612A
Paper handling specifications
Review the following tables for paper handling specifications.
Paper tray capacities
Tray
Capacity
Main input tray
150 sheets of regular weight 75 g/m2 (20-lb paper )
Priority feed slot
10 sheets of paper up to 163 g/m2 (43 lb)
Top (face down) output bin
100 sheets of regular weight 75 g/m2 (20-lb paper )
Output bin
60 to 105 g/m2 (16 lbsto 28lbs )
Paper types and sizes
The product supports media within the following size ranges.
  • Minimum: 76 x 127 mm (3 x 5 inches)
  • Maximum: 216 x 356 mm (8.5 x 14 inches)
Paper type
Metric
English
Letter
216 x 279 mm
8.5 x 11 inches
Legal
216 x 356 mm
8.5 x 14 inches
Executive
184 x 267 mm
7.25 x 10.5 inches
A4
210 x 297 mm
8.25 x 11.75 inches
COM10 envelopes
105 x 241 mm
4.13 x 9.5 inches
DL envelopes
110 x 220 mm
4.33 x 8.67 inches
C5 envelopes
162 x 229 mm
6.4 x 9 inches
B5 envelopes
176 x 250 mm
6.9 x 9.85 inches
Monarch envelopes
98.5 x 191 mm
3.88 x 7.55 inches
Labels
216 x 279 mm
8.5 x 11 inches
Custom-size media
custom (within acceptable range)
Printing specifications
Narrow and heavy paper can cause the product to print more slowly.
Print speed
14 A4 pages per minute (ppm), 15 letter-size ppm
First page out in as low as 10 seconds
Print resolution
600 x 600 dpi with HP Resolution Enhancement technology (REt).
1200 dpi effective output quality (600 x 600 x 2 dpi with HP Resolution Enhancement technology (REt)).
Duty cycle
8,000 single-sided pages per month (maximum)
1,000 single-sided pages per month (average)
Power specifications
Review the following tables for power specifications.
  warning:
Power requirements are based on the country/region where the product is sold. Do not convert operating voltages. Doing so might damage the product and void the product warranty.
Power requirements
Model voltage
Power requirements
Rated current
110-volt
100-127V (+/-10%)
50/60 Hz (+/-2 Hz)
3.5 amps
230-volt
220-240V (+/-10%)
50/60 Hz (+/-2 Hz)
2 amps
Power consumption
Printing
Ready
Off
250 Watts
2 Watts
0 Watts
Power reported is highest values measured for monochrome printing using all standard voltages.
Environmental specifications
The following information contains the environmental specifications for the product.
Operating conditions
Condition
Operating
Storage
Temperature
10°C to 32.5°C (50°F to 90.5° F)
0°C to 40°C (32°F to 104°F)
Relative Humidity
20% to 80% (no condensation)
10% to 80% (no condensation)
Acoustic emissions
Configuration tested: HP LaserJet P1020 printer, continuous monochrome printing on A4 paper at 14 PPM.
Sound power level
Declared per ISO 9296
Printing (14 PPM)
LWAd = 6.2 Bels (A) [62 dB (A)]
Ready (PowerSave)
Inaudible
Sound pressure level bystander position
Declared Per ISO 9296
Printing (14 PPM)
LWAd = ≤4.9 Bels (A) and 49dB (A)
Ready (PowerSave)
Inaudible
Material safety data sheets
Click here to get the Material safety data sheets (MSDS).
FCC compliance
This equipment has been tested and found to comply with the limits for a Class B digital device, pursuant to Part 15 of the FCC rules. These limits are designed to provide reasonable protection against harmful interference in a residential installation. This equipment generates, uses, and can radiate radio frequency energy. If it is not installed and used in accordance with the instructions, it may cause harmful interference to radio communications. However, there is no guarantee that interference will not occur in a particular installation. If this equipment does cause harmful interference to radio or television reception, which can be determined by turning the equipment off and on, the user is encouraged to try to correct the interference by one or more of the following measures:
  • Reorient or relocate the receiving antenna.
  • Increase separation between equipment and receiver.
  • Connect equipment to an outlet on a circuit different from that to which the receiver is located.
  • Consult your dealer or an experienced radio/TV technician.
Any changes or modifications to the printer that are not expressly approved by Hewlett-Packard could void the user's authority to operate this equipment.
Use of a shielded interface cable is required to comply with the Class B limits of Part 15 of FCC rules.
