note:The following specifications are correct at the time of publication, but they are subject to change. For current information, see https://support.hp.com/us-en/products/printers/pagewide-printers.
Model name
750dn
750dw
P75050dn
P75050dw
Tray capacity (75 gsm or 20-lb bond paper)
Tray 1: 100 sheets
Tray 2: 550 sheets
Output bin: 500 sheets
Print
One-sided printing speeds up to 35 pages per minute (ppm) in black and color in Professional mode
One-sided printing speeds up to 50 pages per minute (ppm) in black and color in Professional mode
Two-sided printing speeds up to 24 ppm in black and color in Professional mode
Two-sided printing speeds up to 35 ppm in black and color in Professional mode
Up to 55 ppm in General Office mode
Up to 70 ppm in General Office mode
Plug-and-print with Host USB Type A port
Printing of MS Office documents
Connectivity
802.3 LAN (10/100/1000) Ethernet port
Host USB Type A ports (front and back)
Device USB Type B port (back)
Wireless
Embedded wireless capability
802.11n dual-band support
NFC-enabled (Near Field Communications); walk-up printing from smart phones and tablets
Bluetooth Smart
Wi-Fi Direct
Optional accessories
550-sheet tray
550-sheet tray and stand
3x550-sheet tray and stand
4000-sheet high-capacity input trays and stand
128GB eMMC (embedded MultiMediaCard)
Hardware integration pocket (for connecting accessory and third-party devices)
Windows 10, 32-bit and 64-bit
Windows 8.1, 32-bit and 64-bit
Windows 8, 32-bit and 64-bit
Windows 7, 32-bit and 64-bit
Windows Vista®, 32-bit
Windows® XP SP3, 32-bit
OS X 10.10 Yosemite, OS X 10.11 El Capitan, OS X 10.12 Sierra
Linux (For more information, see hp.com/go/linuxprinting)
UNIX (For more information, see hp.com/go/unixmodelscripts)
Windows® 10, 8.1, 8, 7
Windows Vista®
Windows® XP SP3 or higher (32-bit only)
Apple® OS X v10.12 Sierra, OS X v10.11 El Capitan, OS X v10.10 Yosemite
HP PCL 6 driver
HP UPD PS driver
HP UPD PCL 6
note:Download additional printer drivers from the HP Customer Support website.
Height - mm (in)
Depth - mm (in)
Width - mm (in)
Weight - kg (lb)
750dn, 750dw, P75050dn, P75050dw
457 (18)
531 (20.9)
598 (23.5)
50.2 (111)
note:Power requirements are based on the country/region where the product is sold. Do not convert operating voltages. This will damage the product and any such damage is not covered under the HP limited warranty and service agreements.
Operation
LwAd-mono (B)
LwAd-color (B)
Print
6.9
6.8
Operating
Transporting
Temperature
15° to 30° C
(59° to 86° F)
–40° to 60° C
(–40° to 140° F)
Relative humidity
20 to 80%
90% or less (non-condensing)
Altitude
0 to 3048 m
caution:Use caution when moving the product after cartridges have been installed. The product is designed to operate within a levelness of ±3 degrees.
note:If an electrostatic discharge occurs when using the product to copy, a line can appear on the copied page. The ESD should clear if you copy the page again.
note:Values are subject to change. For the latest information, contact the printer administrator or technical support.
