![HP Reverb G2 Virtual Reality Headset](/wcc-assets/document/images/215/c06938210.png)
Feature
Processor
Intel Core i5, i7, Intel Xeon E3-1240 v5, equivalent or higher
AMD Ryzen 5 equivalent or higher
Memory
8 GB RAM or more
Video out
DisplayPort 1.3 port
USB ports
(1) USB 3.0 Type-C port
Power
USB Type-C with power delivery or included power adapter
Windows 10 May 2019 update or later
Graphics
DirectX 12 capable graphics
Workstations
Graphic cards that typically run Reverb at full resolution
NVIDIA Quadro P5200
NVIDIA Quadro RTX 4000, NVIDIA Quadro RTX 5000, NVIDIA Quadro RTX 6000, and NVIDIA Quadro RTX 8000
AMD Radeon Pro WX 8200 and AMD Radeon Pro WX 9200
AMD Radeon Pro W5700
Graphic cards that typically run Reverb at half resolution
NVIDIA Quadro P3200, NVIDIA Quadro P4000, NVIDIA Quadro P4200, and NVIDIA Quadro P5000
NVIDIA Quadro RTX 3000
AMD Radeon Pro WX 7100
Consumer
NVIDIA GeForce GTX 1080 and NVIDIA GeForce GTX 1080 Ti
NVIDIA GeForce RTX 2060 SUPER, NVIDIA GeForce RTX 2070, NVIDIA GeForce RTX 2070 SUPER, NVIDIA GeForce RTX 2080, NVIDIA GeForce RTX 2080 SUPER, and NVIDIA GeForce 2080 Ti
NVIDIA GeForce RTX 3070, NVIDIA GeForce RTX 3080, and NVIDIA GeForce RTX 3090
AMD Radeon RX 5700, AMD Radeon RX 5700 XT, and AMD Radeon 7
NVIDIA GeForce GTX 1060, NVIDIA GeForce GTX 1660, NVIDIA GeForce GTX 1660 Ti, and NVIDIA GeForce
GTX 1070
AMD Radeon RX 580, AMD Radeon RX 5500XT, AMD Radeon RX 590, AMD Radeon RX 5600 XT, AMD
Radeon RX Vega, and AMD Radeon RX Vega
Feature
Screen
Dual LCD 7.34 cm (2.89 in) diagonal with Pulse Backlight technology
Resolution
2160 x 2160 panel resolution per eye
4320 x 2160 pixels combined
RGB sub-pixels
Supported systems
Windows Mixed Reality platform ecosystem (requires Windows 10 May 2019 update)
SteamVR ecosystem
Field of view
About 114°
Fresnel-Aspherical
Tracking
Two front-facing cameras
Two side-facing cameras
Sensors
HP Reverb G2 inside/out (Six Degrees of Freedom)
Gyroscope, Accelerometer, and magnetometer
Eye adjustments
64 mm +/- 4 mm by hardware slider
Refresh rate
90 Hz with recommended system specs
Connections
USB 3.0 Type-C port
Power adapter connector
Cables
(1) 2-in-1 DisplayPort 1.3 and USB 3.0 Type-C cable 6.0 m (19.68 ft)
(1) Power adapter (for use when
USB Type-C does not have power delivery)
(1) Mini DisplayPort to full-size DisplayPort adapter
Tracked area requirements
No minimum space requirements
Mechanical ID
Replaceable face cushions
Physical specifications
Dimensions
7.49 x 18.59 x 8.40 cm (2.95 x 7.32 x 3.31 in)
550 g (1.21 lb)
Feature
Sensors
HP Reverb G2 tracking, IMU, and active LEDs
Connections
Bluetooth
Inputs
A&B (right) or X&Y (left) buttons
Menu button
Windows button
Analog grip
Analog trigger
Thumbstick
Pairing button (pre-paired to HMD)
Power
Two AA batteries per controller (included in box
Dimensions
6.60 x 12.7 x 11.94 (2.6 x 5.0 x 4.7 in)
167 g (0.34 lb)
Feature
Content
Headset cable for desktop and mobile PC (6.0 m (19.68 ft))
Power adapter
(2) Motion controllers
(1) DisplayPort to mini-DisplayPort adapter
Setup document
