HP EliteBook 745 G5 Notebook PC
Specification
Preinstalled
Windows 10 Pro 64 (National Academic only)
note: Windows 10 Pro 64
note: FreeDOS 1.2
note:In accordance with Microsoft support policy, HP does not support the Windows 8 or Windows 7 operating system on products configured with Intel and AMD 7th generation or later processors, or provide any Windows 8 or Windows 7 drivers.
Specification
AMD Ryzen 7 2700U APU
2.2 GHz base frequency, up to 3.8 GHz burst frequency
6 MB cache and 4 cores
Radeon Vega Graphics
AMD Ryzen 5 2500U APU
2 GHz base frequency, up to 3.6 GHz burst frequency
AMD Ryzen 3 2300U APU
2 GHz base frequency, up to 3.4 GHz burst frequency
Integrated with processor
note:Multicore is designed to improve performance of certain software products. Not all customers or software applications necessarily benefit from use of this technology. Performance and clock frequency vary depending on application workload and hardware and software configurations. Intel numbering is not a measurement of higher performance.Processor speed denotes maximum performance mode; processors run at lower speeds in battery optimization mode.
Specification
Integrated
AMD Radeon Vega Graphics
Specification
Non-touch¹
35.6 cm (14 in) diagonal FHD IPS anti-glare LED-backlit, 220 cd/m², 45% sRGB (1920 x 1080)
35.6 cm (14 in) diagonal FHD IPS anti-glare LED-backlit, 220 cd/m², 45% sRGB with HD camera (1920 x 1080)
35.6 cm (14 in) diagonal FHD IPS anti-glare LED-backlit, 220 cd/m², 45% sRGB with HD IR webcam (1920 x 1080)
35.6 cm (14 in) diagonal FHD IPS anti-glare LED-backlit, 220 cd/m², 45% sRGB for WWAN (1920 x 1080)
35.6 cm (14 in) diagonal FHD IPS anti-glare LED-backlit, 220 cd/m², 45% sRGB with HD camera for WWAN (1920 x 1080)
35.6 cm (14 in) diagonal FHD IPS anti-glare LED-backlit, 220 cd/m², 45% sRGB with HD IR webcam for WWAN (1920 x 1080)
35.6 cm (14 in) diagonal FHD IPS anti-glare LED-backlit, 400 cd/m², 72% sRGB with Ambient Light Sensor and HD IR webcam
(1920 x 1080)
HP Sure View Integrated Privacy Screen 35.6 cm (14 in) diagonal FHD IPS anti-glare LED-backlit, 700 cd/m², 72% sRGB with HD
note: |
Touch¹
35.6 cm (14 in) diagonal FHD IPS LED-backlit touch screen with Corning Gorilla Glass 3, 220 cd/m², 45% sRGB with HD IR
Supported displays (maximum resolution)
HDMI 1.4b
Up to 4K at 60 Hz
Four independent displays when on HP UltraSlim Docking Station
2K at 60 Hz via DisplayPort1
2K at 60 Hz via DisplayPort2
1920 x 1200 at 60 Hz via VGA
Four independent displays when on HP Elite USB-C Dock G4
1920 x 1200 at 60 Hz via HDMI
Four independent displays when on HP Thunderbolt Dock G2
2560 x 1440 at 60 Hz via DisplayPort1
1920 x 1080 at 60 Hz via DisplayPort2
1920 x 1080 at 60 Hz via VGA
note:¹Sold separately or as an optional feature.High-definition (HD) content is required to view high definition images.Resolutions are dependent upon monitor capability, and resolution and color depth settings.
Specification
Primary M.2 Solid State Drive storage
128 GB SATA-3 SS TLC
256 GB PCIe NVMe SS
256 GB PCIe Gen 3x4 NVMe SS TLC
256 GB SATA-3 SS TLC Opal 2
360 GB PCIe Gen 3x4 NVMe SS TLC (Intel)
512 GB PCIe Gen 3x4 NVMe SS TLC
512 GB PCIe Gen 3x4 NVMe SS TLC Opal 2
512 GB SATA-3 SS TLC FIPS-140-2
note:For solid state drives or hard drives, GB = 1 billion bytes. TB = 1 trillion bytes. Actual formatted capacity is less. Up to 30 GB (for Windows 10) is reserved for system recovery software.
Specification
Standard
DDR4 SODIMMS
(2) Dual-channel SODIMM slots (Slots are customer accessible/upgradable)
Runs at 2400 MT/s
Configurations
32 GB DDR4-2400 SDRAM (16 GB x 2)
16 GB DDR4-2400 SDRAM (16 GB x 1)
16 GB DDR4-2400 SDRAM (8 GB x 2)
8 GB DDR4-2400 SDRAM (8 GB x 1)
8 GB DDR4-2400 SDRAM (4 GB x 2)
4 GB DDR4-2133 SDRAM (4 GB x 1)
Maximum
32 GB
note:Due to the non-industry standard nature of some third-party memory modules, we recommend HP branded memory to ensure compatibility. If memory speeds are mixed, the system performs at the lower memory speed.
Specification
Ports
(1) USB Type-C (Alt Mode)
(1) USB 3.1 Gen 1
(1) USB Type-C (Charging)
(1) HDMI 2.0
(1) VGA port
(1) RJ-45/Ethernet port
(1) Headphone/microphone combo jack
(1) AC power port
note: |
Slot
(1) Docking connector
Specification
Wireless LAN (WLAN)
Intel Dual Band Wireless-AC 8265 802.11a/b/g/n/ac (2x2) Wi-Fi and Bluetooth 4.2 Combo, non-vPro
Realtek RTL8822BE 802.11ac (2x2) Wi-Fi and Bluetooth 4.2 Combo, non-vPro
note: |
WWAN
HP lt4132 LTE/HSPA+ 4G Mobile Broadband
Intel XMM 7360 LTE-Advanced
note: |
Near Field Communication (NFC)
NXP NPC300 Near Field Communication Module
Miracast
Yes
Ethernet
Realtek PCIe GbE Family Controller 10/100/1000
note: |
Specification
Audio
Bang & Olufsen
(3) Integrated multi-array microphones
(2) Integrated stereo speakers
Camera (optional)
HD camera
HD IR webcam
note: |
Specification
HP Premium Collaboration Keyboard with Dual Point
Optional features
Non-backlight, Dual Point, spill-resistant with drain
Backlight, Dual Point, spill-resistant with drain, with HP Dura Keys
Backlight, Dual Point, spill-resistant with drain, with HP Dura Keys and privacy
Pointing devices
Clickpad with multi-touch gestures enabled
Taps enabled as default
Microsoft precision touchpad default gestures support
Function keys
Function keys
F1 – Display switching
F2 – Blank or privacy
F3 – Brightness down
F4 – Brightness up
F5 – Speaker mute
F6 – Volume down
F7 – Volume up
F8 – Microphone mute
F9 – Backlight toggle (for backlit keyboard) or blank
F10 – Num lock
F11 – Wi-Fi toggle
F12 – Calendar
Additional keys
Share/Present
Call Answer
Call End
Hidden function keys
Fn+R – Break
Fn+S – Sys Rq
Fn+C – Scroll Lock
Specification
BIOS
HP BIOSphere Gen4 (requires Intel or AMD 8th generation processors)
BIOS Update via Network
Master Boot Record Security
Power On Authentication
Secure Erase (methods outlined in the National Institute of Standards and Technology Special Publication 800-88)
Absolute Persistence Module2
Pre-boot Authentication
HP Wireless Wakeup
Communication/connectivity
HP Native Miracast support
HP LAN-Wireless Protection
HP Value add software
HP Velocity
HP ePrint Driver with JetAdvantage3
HP Hotkey Support - CMIT
HP Recovery Manager
HP Jumpstart
HP Support Assistant (requires Windows and internet access)
HP Noise Cancellation software
HP PhoneWise
Microsoft products
Buy Office
Manageability
HP Driver packs (available for download)
HP System Software Manager (SSM) (available for download)
HP BIOS Configuration Utility (BCU) (available for download)
HP Client Catalog (available for download)
HP Manageability Integration Kit Gen2 (available for download)
Ivanti Management Suite (subscription required)
HP Collaboration Keyboard
note: |
Client Security software
HP Client Security Suite Gen4 (requires Windows)
HP Security Manager (including Credential Manager and HP Password Manager, and HP Spare Key)
note: HP Power On Authentication
HP Device Access Manager
Microsoft Defender (opt in and Internet connection required for updates)
Security
For Windows 10, Trusted Platform Module (TPM) 2.0 (Infineon SLB9670)
HP BIOSphere Gen4
HP DriveLock/Automatic DriveLock
Secure Erase
SATA 0 and 1 port disablement (via BIOS)
RAID configurations (optional and requires a second hard drive)
Serial, USB enable/disable (via BIOS)
Power-on password (via BIOS)
Setup password (via BIOS)
Support for chassis padlocks and cable lock devices
Integrated hood sensor
HP Sure Click (supports Microsoft Internet Explorer and Chromium)
HP Sure Start Gen4
note: |
Optional security features
HP Fingerprint Sensor (sold separately or as an optional feature)
note:2Absolute agent is activated when customers activate a purchased subscription. Subscriptions can be purchased for terms ranging multiple years. Service is limited, check with Absolute for availability outside the U.S. The Absolute Recovery Guarantee is a limited warranty. Certain conditions apply. Data Delete is an optional service provided by Absolute Software. If utilized, the Recovery Guarantee is null and void. In order to use the Data Delete service, customers must first sign a Pre-Authorization Agreement and either obtain a PIN or purchase one or more RSA SecurID tokens from Absolute Software.3Requires an Internet connection to HP web-enabled printer and HP ePrint account registration. Requires optional broadband module. Broadband use requires separately purchased service contract. Check with service provider for coverage and availability in your area. Separately purchased data plans or usage fees might apply. Print times and connection speeds might vary.
Specification
Power supply
Adapters
HP Smart 45 W External AC adapter
HP 45 W 2-prong Smart AC adapter (Japan only)
HP Smart 65 W External AC adapter
HP Smart 65 W EM External AC adapter
45 W USB Type-C adapter
65 W USB Type-C adapter
Power cord
3-wire plug (C5), 1.8 m (5.91 ft)
3-wire plug (C5), 1.0 m (3.28 ft)
2-wire plug (C5), 1.0 m (3.28 ft) (Japan only)
Duckhead power cord (C5), 1.0 m (3.28 ft) premium (for USB Type-C AC adapters)
Duckhead power cord (C5), 1.8 m (5.91 ft) premium (for USB Type-C AC adapters)
Primary battery
HP 3-cell Long Life (50 WHr) Li-ion
note: |
Battery life
Up to 11 hours and 45 minutes
note: |
Specification
Non-touch
Starting at 1.53 kg (3.37 lb)
Touch
Starting at 1.61 kg (3.56 lb)
note: |
Dimensions (W x D x H)
32.61 x 23.42 x 1.78 cm (12.84 x 9.22 x 0.7 in)
