Figure : HP EliteDisplay E243i 24-inch Monitor
![HP EliteDisplay E243i 24-inch Monitor](/wcc-assets/document/images/719/c05628475.jpg)
Specification
Type
24-inch IPS Micro edge
LED backlit
Viewable image area
(diagonal)
60.96 cm (24 in) widescreen
Panel hardness
3H
Panel active area (W x H)
51.84 x 32.41 cm (20.41 × 12.76 in)
Resolution
1920 x 1200 at 60 Hz
Aspect ratio
16:10
Viewing angle (typical)
Up to 178° horizontal (10:1 minimum contrast ratio)
Up to 178° vertical (10:1 minimum contrast ratio)
Brightness
300 cd/m2
Contrast ratio
1000:1 static (typical)
Dynamic contrast ratio (DCR)
50,000,000:1 dynamic (typical)
Response times
5 ms
Pixel pitch
0.27 mm
Default color temperature
Neutral 6500 K
Backlight lamp life
30,000 hours minimum (to half brightness)
Color support
Up to 16.7 million colors
note: |
Color gamut (typical)
99% sRGB
Anti-glare panel
Yes
Flicker free
Yes
Low blue light capable
Yes
User selectable in On-screen Display
(OSD) menu
note:Actual performance varies.
Specification
Monitor control buttons or switches
Menu/OK
Minus ("-")/Down/Information
Plus ("+") /Up/Viewing Mode
Menu
Exit/Back/Next Input Port
Power
User-assignable function buttons
20
Languages
10 (English, Spanish, German, French, Italian, Dutch, Portuguese, Japanese, Simplified Chinese, and Traditional Chinese)
On-screen Display
(OSD)
user controls
Brightness, Contrast, Color Control, Input Control,
Image Control, Power Control, Menu Control, Management, Language, Information, and Exit
Specification
Native resolution
Preset graphic modes (non-interlaced)
640 x 480 at 60 Hz
720 x 400 at 70 Hz
800 x 600 at 60 Hz
1024 x 768 at 60 Hz
1280 x 720 at 60 Hz
1280 x 800 at 60 Hz
1280 x 1024 at 60 Hz
1440 x 900 at 60 Hz
1600 x 900 at 60 Hz
1680 x 1050 at 60 Hz
1920 x 1080 at 60 Hz
Pixel clock speed
170 MHz (maximum)
Vertical frequency
50 - 60 Hz
Horizontal frequency
30 - 80 kHz
Specification
Connector types
(1) DisplayPort (DP) 1.2
(1) HDMI 1.4
(1) VGA
HDCP support for DisplayPort and HDMI
USB ports
(3) USB 3.0
(2) Downstream and (1) Upstream
Cables (included)
(1) VGA cable 1.8 m (5.91 ft)
(1) DisplayPort (DP) cable, 2.0 m (6.56 ft)
(1) USB 3.0 Type-B to A cable, 1.8 m (5.91)
Specification
Plug and play
Yes
Color
Silver on facing bezel
Side frame
Column stand and foot
Black on rear
cover and stand center trim
Cable management
Integrated into column stand
Effortless cable routing through
the column stand for easy management of power, video, and USB
cables
Tilt range
-5° to + 23° vertical
Swivel range
45° L to 45° R
Display height
adjustment range
150 mm
Pivot rotation
Yes
90° clockwise and counter-clockwise
VESA mounting
Yes
100 mm with integrated mount (included)
Security lock-ready
Yes
Specification
Power supply
Internal
Input power
100 - 240 VAC 50/60 Hz
Maximum power
45 W
note: |
Typical power
35 W
note: |
Energy Saving/Standby Mode
0.5 W
Power cable length
1.9 m (6.23 ft)
Specification
Dimensions
(W × D × H)
Unpacked with stand (highest setting)
53.19 x 21.41 x 36.22 cm (20.94 x 8.43 x 14.26 in)
Packaged
62.51 x 42.01 x 27.30 cm
(24.61 x 16.54 x 10.75 in)
Unpacked without stand (head only)
53.21 x 47.83 x 4.65 cm
(20.95 x 18.83 x 1.83 in)
Unpacked
6.36 kg (14.02 lb)
Packaged
8.95 kg (19.73 lb)
Head only
3.66 kg (8.07 lb)
Specification
Temperature
Operating
5° to 35° C (41° to 95° F)
Non-operating
-20° to 60° C (-4° to 140° F)
Humidity
Operating
20% to 80% non-condensing
Non-operating
5% to 95%
Altitude
Operating
0 to 5,000 m (0 to 16,400 ft)
Non-operating
0 to 12,192 m (0 to 40,000 ft)
Arsenic-free display glass
Yes
White LED backlights
Yes
Mercury-free display backlighting
Yes
Eco-label certifications & declarations
ENERGY STAR
EPEAT Gold 4 (registration varies by country/region)
CEL Grade 2
Microsoft WHQL certification (Windows 7, 8 and 10)
TCO
certified edge
SmartWay transport partnership (NA only)
CE
CB
MSIP
Mexico COC
ICES
ISO 9241-
307
TUS-GS
cTUVus
ISC
CCC
VCCI
FCC
BSMI
WEEE
RCM
ErP
S-mark
Compatibility
Compatible with platforms using the VESA standard video modes
Recommended for use with HP products
Specification
Monitor and accessories
AC power cord, 1.9 m (6.23 ft)
VGA cable, 1.8 m (5.91 ft)
DisplayPort 1.2 cable, 2.0 m (6.56 ft)
USB Type-B to A cable, 1.8 m (5.91)
Integrated VESA mount
Documentation
CD (includes user guide, warranty, and drivers)
HP Display Assistant
