X0H81UA
HP Notebook - 15-ay071nr (Touch) (ENERGY STAR)
Intel® Core™ i3-5005U with Intel HD Graphics 5500 (2 GHz, 3 MB cache, 2 cores)
8 GB DDR3L-1600 SDRAM (1 x 8 GB)
1 TB 5400 rpm SATA
Optical drive
SuperMulti DVD burner
15.6" diagonal HD SVA WLED-backlit touch screen (1366 x 768)
Keyboard
Full-size island-style with numeric keypad
Pointing device
Intel 802.11a/b/g/n/ac (1x1) and Bluetooth® 4.0 combo
1 USB 3.0; 2 USB 2.0; 1 HDMI; 1 RJ-45; 1 headphone/microphone combo
38.4 x 25.5 x 2.37 cm
2.14 kg
45 W AC power adapter
3-cell, 31 Wh Li-ion
DTS Studio Sound™ with 2 speakers
