Feature
Preinstalled
Windows 10 Pro 64
Windows 8.1 Pro 64
Windows 8.1 64
Windows 7 Professional 64 (available through downgrade rights from Windows 10 Pro)
Windows 7 Professional 32 (available through downgrade rights from Windows 10 Pro)
FreeDOS 2.0
NeoKylin Linux 64
Web supported
Windows 10 Pro 64
Windows 10 Home 641
Windows 10 Enterprise 64
Windows 8.1 Pro 64
Windows 8.1 64
Windows 8.1 Enterprise 64
Windows 7 Enterprise 64
Windows 7 Enterprise 32
note: |
Processor
AMD PRO A8 -8600B (1.6 GHz, up to 3.0 GHz, 2MB Cache, 4 Cores) with AMD Radeon R6 Graphics
AMD PRO A10-8700B (1.8 GHz, up to 3.2 GHz, 2MB Cache, 4 Cores) with AMD Radeon R6 Graphics
AMD PRO A12-8800B (2.1 GHz, up to 3.4 GHz, 2MB Cache, 4 Cores) with AMD Radeon R7 Graphics
note: |
Chipset is integrated with processor
Graphics
AMD PRO A8 -8600B with AMD Radeon R6 Graphics
AMD PRO A10-8700B with AMD Radeon R6 Graphics
AMD PRO A12-8800B with AMD Radeon R7 Graphics
AMD Vivid Color Support
AMD UMA Graphics - with shared video memory
Internal
External
Up to 32-bit per pixel color depth
VGA
Port supports resolutions up to 1900 x 1200 external resolution at 60 Hz
DisplayPort
Supports resolutions up to 4096 x 2160 at 60Hz
Resolutions are dependent upon monitor capability, and resolution and color depth settings.
Number of Displays supported with Docking
Supports 3 independent displays if used with optional HP Ultraslim Docking Station.
note: |
Storage and drives
Primary storage
SATA, 2.5 inch hard drives
500 GB 7200rpm Self Encrypting Drive (FIPS-140-2) (Opal 2)
500 GB 7200rpm hard drive
500 GB 7200rpm Self-Encrypting drive (Opal 2)
1 TB 5400rpm hard drive
500 GB Hybrid, 8 GB cache
Mini Card Solid State Drive
M.2 (NGFF) 2280 Solid State Drive
128 GB SATA-3 TLC Solid State Drive
180 GB SATA-3 MLC Solid State Drive
180 GB SATA-3 Self-Encrypting (Opal 2) MLC Solid State Drive
240 GB SATA-3 MLC Solid State Drive
256 GB SATA-3 TLC Solid State Drive
256 GB SATA-3 Self-Encrypting (Opal 2) MLC Solid State Drive
256 GB PCIe-3x4 NVMe Solid State Drive (planned to be available December 2015)
512 GB SATA-3 TLC Solid State Drive (planned to be available December 2015)
HP 3D DriveGuard (Windows and Hard Drives only)
The hard drive is mounted directly to the notebook frame, reducing the transmission of shock to the hard drive
note: |
Memory
Standard
DDR3L PC3L-12800 (Transfer rates up to 1600 MT/s)
Two SODIMM slots supporting dual-channel memory
Both slots are customer accessible / upgradeable
Supports
4096 MB Total System Memory (4096 MB x 1)
8192 MB Total System Memory (4096 MB x 2)
8192 MB Total System Memory (8192 MB x 1)
16384 MB Total System Memory (8192 MB x 2)
Maximum
Up to 16 GB
Dual-channel
Maximized dual-channel performance requires SODIMMs of the same size and speed in both memory slots.
note: |
Networking / communications
Broadband Wireless (WWAN)
HP lt4120 Qualcomm SnapdragonT X5 LTE Mobile Broadband Module 1, 2
HP hs3110 HSPA+ Mobile Broadband Module1, 2
Wireless LAN (WLAN) Via MiniCard
Realtek RTL8188EE 802.11b/g/n (1x1) (Not available for Indonesia)
Broadcom 943228 Dual Band 802.11 a/b/g/n (2x2) Bluetooth 4.0 Combo
Intel 7265 802.11ac(2x2) + Bluetooth 4.1 Combo (Not available for Indonesia)
Near Field Communication (NFC)1
HP Module with NXP NFC Controller NPC100
Support for Miracast
Communications
Broadcom 5762 10/100/1000 Ethernet NIC with DASH Support
note: |
Audio / multimedia
Audio
Audio by Bang & Olufsen
HP Clear Sound Amp
HP Noise Reduction Software
Digital Microphones (Dual Array)
2 Premium Stereo Speakers
Optional 720p webcam
Keyboards / pointing devices / buttons
Pointing Device
Glass touchpad
On/Off button
Taps enabled as default
Gestures enabled by default - 2 finger scrolling, 2 finger zoom (pinch)
Buttons and function keys
F1 - Sleep
F2 - Blank
F3 - Backlit Toggle
F4 - Display Switching
F5 - Brightness Down
F6 - Brightness Up
F7 - Blank
F8 - Volume Down
F9 - Volume Up
F10 - Mic Mute
F11 - Blank
F12 - Blank
