![](/wcc-assets/document/images/244/c04489021.jpg)
HP ZBook 15 G2 Mobile Workstation
Feature
Processor*
note: |
Mobile Intel® QM87
Inel Core i5 with VPRO and Core i7 with VPRO Technology Capable
Intel Core i5 with vPro and Core i7 with vPro technology is a selectable feature that is available on units configured with select processors, a qualified Intel Centrino® WLAN module and a preinstalled Windows operating system. It provides advances in remote manageability, security, energy efficient performance, and wireless connectivity. Intel Active Management Technology 9.0 (iAMT) offers built-in manageability and proactive security for networked mobile workstations, even when they are powered off* or when the operating system is inoperable. It can help identify threats before they reach the network, isolate infected systems, and update regardless of their power state.
note: |
Graphics
Multi-Display Support
note: |
Internal
External
Thunderbolt™ 2*
Supported as part of the daisy chain connected with Intel approved thunderbolt cables. For additional information, please visit https://thunderbolttechnology.net/.
Thunderbolt Features
DisplayPort w/MST (Multi-stream Transport)
Supports resolutions up to QFHD 3840 x 2160, 24/30-bit color depth at 60 Hz, and WUXGA (1920 x 1200) monitors, 24/30-bit color depth at 120 Hz.
DisplayPort Feature
VGA
Port supports resolutions up to 2048 x 1536 at 75 Hz, and lower resolutions at up to 100 Hz.
DVI-D (single link)
Video signal available through DVI port in optional HP Docking Station (sold separately), as well as through DisplayPort to DVI-D; DisplayPort to DVI-D (dual link); and DisplayPort to HDMI adapters.
Supports resolutions up to 1600 x 1200 at both full and reduced blanking, and 1920 x 1200 at reduced blanking.
note: |
Storage and drives
Z Turbo Drive Storage Bay
note: |
Memory
256 GB Z Turbo Drive (PCIe Solid State Drive)
Primary Storage Bay
Hard Drives*
HP 3D DriveGuard (Windows only)
The hard drive is mounted directly to the notebook frame, reducing the transmission of shock to the hard drive. Uses three-axis digital motion detection with intelligent sensitivity to help protect the hard drive during normal use from shock and vibration. The digital accelerometer temporarily halts all data transfer and parks the hard drive when abrupt motion is detected.
Solid State Drive*
note: |
Networking/Communications
Wireless
Support for a broad range of secure, integrated wireless LAN and wireless WAN options featuring support for the latest industry standards. Optional broadband Wireless (WWAN) requires a Windows operating system and is available in select countries as a standard, factory configurable feature only. Integrated Bluetooth® is also available (factory configurable only) and can be combined with any of the supported wireless LAN and wireless WAN options.
Mobile Broadband options
All 802.11 integrated wireless LAN options
Communications
Integrated Integrated Intel® I217-LM Gigabit** Network Connection (vPro configurations)
note: |
Audio/Multimedia
Audio
Optional 720p HD webcam
Keyboard/Pointing devices/Buttons and function keys
Keyboard
Optional backlit keyboard with Function key control to toggle backlit brightness setting - off/full/half brightness The HP spill-resistant keyboard is designed using a thin layer of Mylar film under the keyboard and a drain system that funnels fluid through a hole in the bottom of the notebook. This minimizes the risk of damage to sensitive components underneath. The 101/102-key compatible keyboard features a full-pitch key layout with desktop keyboard features, such as editing keys, both left and right control and alt keys, function keys, and 19.05 x 19.05 mm key pitch (center-to-center spacing). U.S. and International key layouts are available. Other features include hot keys for instant access to power conservation and brightness.
Pointing devices
Buttons and Function Keys
Separate launch buttons provide easy access to the following features: wireless on/off, volume mute. Function keys provide control of the following features: standby mode, external display, volume down, volume up, HP Power Assistant (Windows 7 only), and display brightness.
Specification
Stand-alone power requirements (AC power)
Specification
Active Area (W x H)
34.4 x 19.4 cm (13.54 x 7.59 in)
Diagonal size
39.6 cm (15.6 in)
420 g (max)
Surface treatment
Anti-glare
Contrast ratio
600:1 (min)
Refresh rate
60 Hz
Brightness
300 nits (typ)
Pixel resolution
Backlight
LED
PPI
142
Viewing angle
UWVA 85/85/85/85
Specification
Active Area (W x H)
Diagonal size
39.6 cm (15.6 in)
380 g (max)
Surface treatment
Anti-glare
Contrast ratio
400:1 (min)
Refresh rate
60 Hz
Brightness
300 nits (typ)
Pixel resolution
Backlight
LED
PPI
142
Viewing angle
SVA 45/45/25/35
Specification
Dimensions (H x W)
34.56 x 19.44 cm (13.60 x 7.59 in)
Diagonal size
39.65 cm (15.6 in)
360 g (max)
Surface treatment
Anti-glare
Contrast ratio
600:1 (min)
Refresh rate
60 Hz
Brightness
300 nits (typical)
Pixel resolution
Backlight
LED
PPI
235
Viewing angle
UWVA 85/85/85/85
Specification
Drive weight
115 g (0.25 lb)
Capacity
1 TB
Height
9.5 mm (0.37 in)
Width
69.85 mm (2.75 in)
Interface
ATA-8, SATA 3.0
Transfer rate (synchronous maximum):
600 MB/s
Seek time (typical reads, including settling)
Cache
32 MB
Rotational speeds
7200 rpm
Logical Blocks
1,953,525,168
Operating Temperature
0° to 60° C (32° to 140° F) [top cover temp]
Features
ATA Security, S.M.A.R.T., NCQ, Ultra DMA
Specification
Drive weight
115 g (0.25 lbs)
Capacity
750 GB
Height
9.5 mm (0.37 in)
Width
69.85 mm (2.75 in)
Interface
ATA-8, SATA 3.0
Rotational speed
7200 rpm
Logical blocks
1,465,149,168
Operating temperature [case temp]
Features
ATA Security, NCQ, S.M.A.R.T., Ultra DMA
600 MB/s (Drive Capability)
Cache
Up To 32 MB
Specification
Drive weight
92 g - 115 g (0.20 - 0.25 lbs)
Capacity
500 GB
Height
7/9.7 mm (0.28/0.38 in)
Width
69.85 mm (2.75 in)
Interface
ATA-8, SATA 3.0
Rotational speed
7200 rpm
Logical blocks
976,773,168
Features
Cache
Up To 32 MB
Specification
Drive weight
95 g (0.21 lbs)
Capacity
500 GB
Height
7 mm (0.28 in)
Width
69.85 mm (2.75 in)
Interface
ATA-8, SATA 3.0
Rotational speed
5400 rpm
Logical blocks
976,773,168
Features
ATA Security; TCG Opal 2.x, FIPS, S.M.A.R.T., NCQ, Ultra DMA
Cache
16 MB
note: |
Specification
Drive weight
95 g (0.21 lbs)
Capacity
500 GB
Height
7 mm (0.28 in)
Width
69.85 mm (2.75 in)
Interface
ATA-8, SATA 2.6
Rotational Speed
7200 rpm
Logical blocks
976,773,168
Features
ATA Security; TCG OPAL v1.00, S.M.A.R.T., NCQ, Ultra DMA
300 MB/s (Drive Capability)
Cache
32 MB
Specification
Drive weight
78 g (0.17 lbs)
Capacity
556 GB
NAND Type
MLC
Height
7 mm (0.28 in)
Width
69.85 mm (2.75 in)
Interface
ATA-8, SATA 3.0
Performance
Logical blocks
500,118,192
0° to 70° C (32° to 158° F) [ambient temp]
Features
ATA Security; DIPM; TRIM; DEVSLP
Specification
Drive weight
78 g (0.17 lbs)
Capacity
512 GB
NAND Type
MLC
Height
7 mm (0.28 in)
Width
69.85 mm (2.75 in)
Interface
ATA-8, SATA 3.0
Performance
Logical blocks
1,000,215,216
Features
Specification
Drive weight
78 g (0.17 lbs)
Capacity
240 GB
NAND Type
MLC
Height
7 mm (0.28 in)
Width
69.85 mm (2.75 in)
Interface
ATA-8, SATA 3.0
Performance
Logical blocks
468,862,128
Features
Specification
Drive weight
78 g (0.17 lbs)
Capacity
180 GB
Height
7 mm (0.28 in)
Width
69.85 mm (2.75 in)
Interface
ATA-8, SATA 3.0
Performance
Logical blocks
351,651,888
Features
Specification
Drive weight
78 g (0.17 lbs)
Capacity
128 GB
Height
7 mm (0.28 in)
Width
69.85 mm (2.75 in)
Interface
ATA-8, SATA 3.0
Performance
Logical blocks
250,069,680
0° to 70° C (32° to 158° F) [case temp]
Features
Specification
Drive weight
10 g (0.02 lbs)
Capacity
256 GB
Height
60 mm (0.24 in)
Width
22 mm (0.87 in)
Interface
ATA-8, PCIe 2.0
Performance
Logical blocks
500,118,192
Features
note:*For hard drives and solid state drives, GB = 1 billion bytes. TB = 1 trillion bytes. Actual formatted capacity is less. Up to 16 GB (for Windows 7) of system and up to 30 GB (for Windows 8) disk is reserved for system recovery software.
Specification
Implementation
IDT 92HD91
Function Key Volume controls
Volume up, volume down, and mute
Full duplex
Yes
Microphone in
Stereo
Headphone/Line out
Stereo
Integrated microphone
Yes, dual digital microphone array when equipped with optional webcam
Specification
Frequency response
20 Hz - 20 kHz
Signal to noise ratio
>85 dB
Total harmonic distortion
0.01%
Noise floor
-110 dB
Play/Record sampling rate(s)
8 kHz - 48kHz
DAC
16, 20 or 24-bit
ADC
16 or 20-bit
Specification
Power rating
2 W
Impedance
4 ohms
Dimensions
172 x 96 x 25.4 mm (6.77 x 3.80 x 1.0 mm)
748 g (1.65 lb)
Input
100 to 240 VAC
Output power
Connector
3 pin/grounded, mates with interchangeable cords
Environmental Design
EMI and safety certifications
CE Mark- full compliance with LVD and EMC directives; Worldwide safety standards- IEC950, EN60950, UL1950, Class 1, SELV; Agency approvals- C-UL-US, NORDICS, DENAN, EN55022 Class B, FCC Class B, CISPR22 Class B, CCIB, NOM-1 NYCE; MTBF- over 200,000 hours at 25°C ambient condition.
Dimensions (H x W x L)
167.5 x 82 x 25.4 mm (6.59 x 3.23 x 1.0 in)
565 g) (1.25 lb)
Input
100 to 240 VAC
Output
Connector
Worldwide safety and EMC approvals including CE, UL, CSA or cUL, GS, Australian Electric Permit, C-tick, NOM, CCC, KC, GOST, SABS, S mark, BSMI, ISC, PSE, PSB and SII.
2 x 5.3 x 27 cm (0.8 x 2.1 x 10.6 in)
0.442 kg (0.99 lb)
Cells/Type
Lithium-Ion
Energy
Temperature
Battery Re-Charge Time
Fuel Gauge LED
No
1 year
Compatible with optional Travel Battery
Yes
0.442 kg (0.99 lb)
Cells/Type
8-cell; Lithium-Ion
Energy
Temperature
Fuel Gauge LED
No
Warranty*
3 year
Yes
note: |
3 x 15 x 29 cm (1.2 x 5.9 x 11.4 in)
0.682 kg (1.5 lb)
Cells/Type
Lithium-Ion
Energy
Temperature
Fuel Gauge LED
Yes
1 year
No
3 x 15 x 30.5 cm (1.2 x 6.1 x 12 in)
0.550 kg (1.2 lb)
Cells/Type
Lithium-Ion Polymer
Energy
Temperature
Fuel Gauge LED
Yes
1 year
Yes
Wireless
HP hs3110 HSPA+ Mobile Module
HP lt4112 LTE/HSPA+ Qualcomm® Gobi™ 4G Module
HP lt4211 LTE/EV-DO/HSPA+ Gobi 4G Module
Intel Dual Band Wireless-NB 7260 802.11 a/b/g/n (2x2) WiFi
Intel Dual Band Wireless-AC 7260 802.11 a/b/g/n/ac (2x2) WiFi and Bluetooth 4.0 combo
Intel Dual Band Wireless-AN 7260 802.11 a/b/g/n (2x2) WiFi and Bluetooth 4.0 combo
Communications
note: |
Specification
Dimensions (H x W x D)
1.2 in (at front)/1.4 in (at rear) x 15.0 in x 10.1 in
30.5 mm (at front)/35.5 mm (at rear) x 381.5 mm x 257.0 mm
Height with DreamColor display: 1.34 in/ 34.0 mm at front; 1.54 in / 39 mm at rear
note: |
Starting at 2.78 kg (6.13 lb) with Z Turbo Drive and weight saver (no optical drive)
Starting at 2.93 kg (6.45 lb) with hard drive and DVD-R/W drive
Feature
Security
Windows 8
Windows 7
BIOS Features
Windows 8
Windows 7
MultiMedia
Windows 8
Windows 7
HP Value Add
Windows 8
Windows 7
Microsoft Products
Windows 8
Windows 7
Additional Software Available from the Web
Workstation ISV Certifications
See the latest list of certifications at: http://www.hp.com/united-tates/campaigns/workstations/partnerships.html.
HP Remote Graphics Software
note: |
HP Performance Advisor
HP Recovery Manager
Models shipped with Windows 7 include HP Recovery Manager. HP Recovery Manager enables fast recovery of the factory preinstalled image if the system becomes corrupted or if important system files are accidentally deleted. Up to 36 GB (for Windows 7) of system and up to 36 GB (for Windows 8) disk is reserved for system recovery software.
Security
See Software section above.
Other Standard Security Features
Optional Security Features
note: |
Specification
Temperature
Relative humidity
Shock
Random vibration
Altitude (unpressurized)
Planned Industry Standard
Certifications
note: |
