caution:If you try to print on media that is wrinkled, folded, or damaged in any way, a jam might occur.
note:When you add new media, make sure that you remove all of the media from the input tray and straighten the entire stack. This helps prevent multiple sheets of media from feeding through the product at one time, reducing media jams.
Paper type
How to load paper
Preprinted or letterhead
Prepunched
Envelope
note:Use the priority input slot for printing one envelope or other special media. Use the main-input tray for printing multiple envelopes or other special media.
