The latest HP printer software for this device is built into Tiger for print only functionality and does not require a download or reinstallation of any HP software to print.
In order to best take advantage of the latest HP driver and new Mac OS X v10.4 Tiger features, it is recommended that you delete original HP printer queues from Printer Setup Utility and create a new HP printer queue.
Tiger - HP printer setup instructions:
Upgrade install from Mac OS X v10.1, 10.2, 10.3 - select 'Reset Printing System" option (from the Printer Setup Utility pull down menu) to delete all previous printer queues. The HP printer queue can also be deleted manually from Printer Setup Utility.
From Printer Setup Utility, click on Add, select connection type (e.g. All, Bonjour, USB, Appletalk) and create new HP printer queue. The Printer Setup Utility is found in the Applications/Utilities folder.
Clean install - If there is a clean install of Tiger, follow step 2 to add a new HP printer queue.
Uwaga:
Please note that Stuffit Expander is no longer included with Tiger, .sit file downloads will require downloading Stuffit URL at http://www.stuffit.com/mac/downloads.html. This link will take you outside the Hewlett-Packard web site. HP does not control and is not responsible for information outside the HP web site.
