HP ZBook 15 Mobile Workstation
Feature
Mobile Intel QM87
Processors
Graphics1
Microsoft DirectX 11.1 (Shader Model 5.0) and OpenGL 4.2 capable
Storage and drives
Optical drives
Memory
Networking/Communications
Audio/Multimedia
note: |
Specification
Stand-alone power
requirements (AC power)
Nominal operating voltage: 19.5 V
Average operating power:
Max operating power: Less than 150 W or less than 200 W
Temperature
Operating
Non-operating
Relative humidity
Operating: 10% to 90%, non-condensing
Non-operating: 5% to 95%, 101.6° F (38.7° C) maximum wet bulb temperature
Shock
Operating: 40 G, 2 ms, half-sine
Non-operating: 200 G, 2 ms, half-sine
Random Vibration
Operating: 0.75 grms
Non-operating: 1.50 grms
Altitude (unpressurized)
Operating:
-15.24 to 3,048 m (-50 to 10,000 ft)
Non-operating:
-15.24 to 12,192 m (-50 to 40,000 ft)
Planned industry
standard
certifications
Specification
Active area (W x H)
34.4 x 19.4 cm (13.54 x 7.59 in)
Dimensions (W x H)
39.6 cm (15.6 in)
420 g (max)
Surface treatment
Anti-glare
Contrast ratio
600:1 (min)
Refresh rate
60 Hz
Brightness
300 nit (typical)
Pixel resolution
Backlight
LED
PPI
142
Viewing angle
UWVA 85/85/85/85
Specification
Active area (W x H)
Dimensions (W x H)
39.6 cm (15.6 in)
Surface treatment
Anti-glare
Contrast ratio
800:1 (min)
Refresh rate
48 Hz, 50 Hz and 60 Hz
Brightness
210 nits (typical)
Pixel resolution
Backlight
RGB LED
PPI
142
Viewing angle
±89° Horizontal, ±89° Vertical (typical)
Technology type
30-bit In-Plane Switching (IPS)
Color depth
10-bits/color
Display colors
Over 1 billion colors (native mode)
Color gamut coverage
NTSC:
AdobeRGB
sRGB
Specification
Active area (W x H)
Dimensions (W x H)
39.6 cm (15.6 in)
380 g (max)
Surface treatment
Anti-glare
Contrast ratio
400:1 (min)
Refresh rate
60 Hz
Brightness
300 nit (typical)
Pixel resolution
Backlight
LED
PPI
142
Viewing angle
UWVA 85/85/85/85
Specification
Drive weight
115g (0.25 lb)
Capacity
1TB
Height
9.5 mm (0.37 in)
Width
70 mm (2.75 in)
Interface
ATA-8, SATA 2.6, 3.0 Gb/s, NCQ
Transfer rate
Synchronous (maximum) 300MB/s (Drive Capability)
Seek time
(typical reads, including
settling)
Cache
16MB
Rotational speed
5400 rpm
Logical blocks
1,953,525,168
Operating temperature
0° to 60° C (32° to 140° F) [case temp]
Features
ATA security
Specification
Drive weight
115g (0.25 lb)
Capacity
500GB
Height
9.5 mm (0.37 in)
Width
70 mm (2.75 in)
Interface
Transfer rate
Seek time
settling)
Cache
16GB
Rotational speed
7200 rpm
Logical blocks
976,773,168
Features
ATA security
Specification
Drive weight
115g (0.25 lb)
Capacity
500GB
Height
7 mm (0.28 in)
Width
70 mm (2.75 in)
Interface
Transfer rate
Seek time
settling)
Cache
16MB
Rotational speed
5400 rpm
Logical blocks
976,773,168
Features
ATA security
Specification
Drive weight
115g (0.25 lb)
Capacity
500GB
Height
9.5 mm (0.37 in)
Width
63.5 mm (2.50 in)
Interface
Transfer rate
Seek time
settling)
Cache
16MB
Rotational speed
7200 rpm
Logical blocks
976,773,168
Features
ATA security
Specification
Drive weight
115g (0.25 lb)
Capacity
320GB
Height
9.5 mm (0.37 in)
Width
70 mm (2.75 in)
Interface
Transfer rate
Seek time
settling)
Cache
16MB
Rotational speed
7200 rpm
Logical blocks
625,142,448
Features
ATA security
Specification
Drive weight
73g
Capacity
512GB
Height
7 mm (0.276 in)
Width
70 mm (2.76 in)
Interface
SATA Gen 3 (6 Gb/s)
Performance
Logical blocks
1,000,215,216
0° to 70° C (32° to 158° F) [case temp]
Features
ATA security; ATA-8; SATA 3.0 DIPM; TRIM
Specification
Drive weight
73g
Capacity
128GB
Height
7 mm (0.276 in)
Width
70 mm (2.76 in)
Interface
SATA 3 (6 Gb/s)
Performance
Logical blocks
250,069,680
Features
Specification
Access times
Random:
Less than 140 ms CD (typical)
Less than 160 ms DVD (typical)
Max data transfer rate
Transfer Mode
UDMA Mode 5
Interface
Gen 1 SATA
Supported Media (read)
CD-DA, CD-TEXT, CD-ROM, CD-ROM XA, MIXED MODE CD, CD-I, CD-I Bridge
(Photo-CD, Video CD), Multisession CD (Photo-CD, CD-EXTRA, Portfolio, CD-R,
CD-RW), CD-R, CD-RW, DVD-ROM (DVD-5, DVD-9, DVD-10, DVD-18), DVD-R,
DVD-RW, DVD+R, DVD+RW, DVD-RAM
Supported Media (write)
None
Max Media Capacity (read)
8.5GB
Transport
Tray Loading
Specification
Access times
Random:
Transfer Mode
UDMA Mode 5
Interface
Gen 1 SATA
CD-R, CD-RW, DVD+R, DVD+RW, DVD-R, DVD-RW, DVD-RAM, DVD+R DL, DVD-R
DL
8.5GB
Max Media Capacity
(write)
8.5 GB
Transport
Tray Loading
Specification
Access times
Random:
Less than 190 ms CD-ROM (typical)
Less than 180ms DVD-ROM (typical)
Less than 230 ms BD-ROM (typical)
Transfer Mode
UDMA Mode 5
Interface
Gen 1 SATA
CD-DA, , CD-TEXT, CD-ROM, CD-ROM XA, MIXED MODE CD, CD-I, CD-I Bridge
DVD-RW, DVD+R, DVD+RW. DVD-RAM, BD-ROM, BD-R, BD-RE
CD-R, CD-RW, DVD+R, DVD+R DL, DVD+RW, DVD-R, DVD-R DL, DVD-RW, DVDRAM
50.0 GB
Max Media Capacity
(write)
8.5 GB
Transport
Tray Loading
Specification
Access times
Random:
Less than 165 ms CD-ROM (typical)
Less than 185 ms DVD-ROM (typical)
Less than 205 ms BD-ROM (typical)
Transfer Mode
UDMA Mode 5
Interface
Gen 1 SATA
CD-R, CD-RW, DVD+R, DVD+R DL, DVD+RW, DVD-R, DVD-R DL, DVD-RW, DVDRAM,
BD-R, BD-RE
50.0 GB
Max Media Capacity
(write)
50.0 GB
Transport
Tray Loading
Specification
Ethernet Features
Power
Management
Performance
Features
Manageability
Interface
PCI Express 1.1 x1 to fully support ASPM L0s/L1 and CLKREQ.
NIC Device Driver Name
Intel Ethernet Network Connection I217-LM
Specification
Technology/Operating
Bands
Wireless Protocol
Standards
Wireless Parametric
Standards
Complies with 3GPP specifications
Maximum Data Rates
GPS
GPS Standalone, A-GPS: L1 (Internet- and Network assisted
GPS Bands
1575.42 MHz (± 1.023 MHz)
Maximum Output Power
Maximum Power
Consumption
2500mA (peak); 600mA (average)2700mA (peak)
Power Consumption,
Sleep Mode
3.6 mA
Power Management
USB selective suspend, Connected Standby
Integrated notebook wireless button
Antenna Type
Dual high efficiency 5 band antennae with spatial diversity, mounted in the
display enclosure
Form Factor
M.2 Socket 2, USB 2.0 interface high speed
Less than 6g
Specification
Bands
Wireless Protocol
Standards
Wireless Parametric
Standards
Complies with 3GPP specifications Release 8 for LTE
Maximum Data Rates
GPS
Standalone GPS, A-GPS, GPS XTRA
GPS Bands
LTE: +23 dBm (+/- 1 dBm)
Maximum Power
Consumption
Power Consumption,
Sleep Mode
2 mA
Power Management
USB selective suspend, Integrated notebook wireless button
Antenna Type
Dual high efficiency multi-band antennae with spatial diversity
Form Factor
M.2, 3042-S3 Key B
Less than 6g
Dimensions
(Length x Width x
Thickness)
42 mm × 30 mm × 2.3 mm
Voltage, Operating
3.135 V to 4.4 V (3.3 V +1.1V/-0.165V)
Temperature, operating
(from TIA/EIA/IS-98-D)
-13° to 140° F (-25° to 60° C)
Temperature, nonoperating,
96 hours (from
MIL-STD 202 Method 108)
-40° to 185° F (-40° to 85° C)
Humidity, non-operating
95% relative humidity for 48 hours @ 185° F (85° C) (non-condensing)
LED activity
LED Off - Radio Off; Solid LED On - Radio On
Specification
Bands
Wireless Protocol
Standards
Wireless Parametric
Standards
Maximum Data Rates
GPS
Standalone
GPS Bands
1575.42 MHz (± 1.023 MHz), GLONASS 1596-1607MHz
Maximum Power
Consumption
Power Consumption,
Sleep Mode
3 mA
Power Management
Antenna Type
Form Factor
M.2, USB 2.0 interface
6g
Dimensions
(Length x Width x
Thickness)
Voltage, Operating
–10° to 55° C (14° to 131° F)
96 hours (from
–40° to 85° C (–40° to 185° F)
LED activity
Specification
Wireless LAN Standards
Interoperability
Wi-Fi certified
Frequency Band
802.11b/g/n
802.11a/n
Data Rates
Modulation
Direct Sequence Spread Spectrum
BPSK, QPSK, CCK, 16-QAM, 64-QAM, 256-QAM
Security
Network Architecture
Models
Roaming
IEEE 802.11 compliant roaming between access points
Output Power
Power Consumption
ACPI and PCI Express compliant power management
802.11 compliant power saving mode
Receiver Sensitivity
Antenna type
Specification
Implementation
IDT 92HD91
Function key volume
Volume up, volume down, and mute
Full duplex
Yes
Microphone in
Stereo
Headphone/line out
Stereo
Integrated microphone
Yes, dual digital microphone array when equipped with optional webcam
Audio output quality
Frequency response
20 Hz - 20 kHz
Signal to noise ratio
Less than 85 dB
Total harmonic distortion
0.01%
Noise floor
- 110 dB
Play/Record sampling
rate(s)
8 kHz - 48 kHz
D ac
16, 20 or 24-bit
ADC
16 or 20-bit
Internal stereo speakers
Power rating
2 W
Impedance
4 ohms
HP 65W EM Smart AC
Adapter
Specification
Dimensions
12.65 x 5.0 x 3.0 cm (4.98 x 1.97 x 1.18 in)
290 g (0.62 lb)
Input
190 to 265 V ac
Input Efficiency: 87% min at 115 V ac
Input frequency range: 47 to 63 Hz
Input ac current: 1.7 A at 90 V ac
Output
Output power: 65W
DC output: 19.5V
Hold-up time: 5 msec at 115 V ac input
Output current limit: less than 11 A, Over voltage protection- 29V max
automatic shutdown
Connector
3 pin/grounded, mates with interchangeable cords
Environmental design
Operating
temperature: 0° to 35° C (32° to 95° F)
Non-operating (storage) temperature: -20° to 85° C (-4° to 121° F)
Altitude: 0 to 5,000 m (0 to 16,405 ft)
Humidity: 0% to 95%
Storage Humidity: 0% to 95%
EMI and safety
certifications
CE Mark - full compliance with LVD and EMC directives; Worldwide safety
standards - IEC60950, EN60950, UL60950, Class1, SELV; Agency approvals -
C-UL-US, NORDICS, DENAN, EN55022 Class B, FCC Class B, CISPR22 Class B,
CCC, NOM-1 NYCE; Reliability - failure rate of less than 0.1% annually within
the first three years of operation.
HP 200W Slim Smart AC
Adapter
Dimensions
172 x 96 x 25.4 mm (6.77 x 3.80 x 1.0 in)
Weight (max)
748 g (1.65 lb)
Input
100 to 240 VAC
Output
Connector
Environmental Design
Operating
temperature
0° to 40° C (32° to 104° F)
-20° to 65° C (-4° to 149° F)
Altitude
0 to 3,048 m (0 to 10,000 ft)
Humidity
20% to 80%
Storage Humidity
10% to 90%
EMI and Safety
Certifications
CE Mark- full compliance with LVD and EMC directives; Worldwide safety
standards- IEC950, EN60950, UL1950, Class 1, SELV; Agency approvals- C-ULUS,
NORDICS, DENAN, EN55022 Class B, FCC Class B, CISPR22 Class B, CCIB,
NOM-1 NYCE; MTBF- over 200,000 hours at 25°C ambient condition.
HP 150W Slim Smart AC
adapter
Specification
Dimensions
6.59 x 3.23 x 1.0 in (167.5 x 82 x 25.4 mm)
565 g (1.25 lb)
Input
100 to 240 VAC
Input Efficiency 87% min at 115 VAC
Input frequency range 47 to 63 Hz
Input AC current Less than 2.7 A at 90 VAC
Output
Output power 150W
DC output 19.50V +5.0%/-5.0%
Hold-up time 5 msec at 115 VAC input
Output current limit Less than 15A, Over voltage protection- 29V max
automatic shutdown
Connector
Operating
temperature 5° to 35° C (41° to 95° F)
temperature-20° to 85° C (-4° to 185° F)
Altitude Humidity
EMI and Safety
Certifications
Worldwide safety and EMC approvals including CE, UL, CSA or cUL, GS,
Australian Electric Permit, C-tick, NOM, CCC, KC, GOST, SABS, S mark, BSMI, ISC,
PSE, PSB and SII.
HP 8-cell Lithium-Ion
Battery (83 WHr)
Dimensions
2 x 5.3 x 27cm (0.8 x 2.1 x 10.6 in)
Weight (max)
0.442 kg (0.99lb)
Cells/Type
Lithium-Ion
Energy
Temperature
Operating (Charging: 0° to 45° C (32° to 113° F)
Operating (Discharging) F(-10° to 50° C (14° to 122°)
Non-operating: -20° to 50° C -4° to 122° F
Battery Re-Charge Time
System in OFF or Standby: 2.5 hours
System ON : 3 to 5 hours
Fuel Gauge LED
No
1 year
Compatible with optional
Travel Battery
Yes
Specification
Dimensions (H x W x L)
Weight (max)
0.442 kg (0.99lb)
Cells/Type
8-cell; Lithium-Ion
Energy
Temperature
Operating (Discharging) 10° to 60° C (14° to 140° F)
Non-operating: -20° to 60° C (-4° to 140° F)
Mode:
2.5 hours
System ON: 3 to 5 hours
Fuel Gauge LED
No
3 year
Travel Battery
Yes
Feature
Weights and dimensions
Dimensions (w x d x h)
Ports/Slots
Ports
Digital media slots
note: |
Feature
Preinstalled software with Windows operating system
Preinstalled
HP Remote Graphics Software
HP Performance Advisor
HP Recovery Manager
Security
Standard
Specification
HP Fingerprint Sensor
(optional)
Mobile voltage operation
3.0V -3.6V single supply
-10° - 75°C (14° - 167°F)
Current consumption
36mA
Low latency wait for
finger
950 uA
Capture rate
3000 lines/sec
ESD Resistance
IEC 6100-4-2 4B (+/-15KV)
Detection matrix
200*1 (plus another secondary line); 508 dpi, sensor area 12*3 mm
