This document is for HP Laser MFP 135/137 and Color Laser MFP 178/179 Printers.
This document provides information about how to resolve common toner cartridge-related messages.
주의:HP recommends that you use genuine HP supplies. HP cannot guarantee the quality or reliability of non-HP or refilled cartridges. If you do not use genuine HP cartridges, the steps in this document may not resolve the issue. To check the authenticity of your cartridges, go to hp.com/go/anticounterfeit.
주의:This document does not contain all error codes for HP Laser printers. It includes only the most common messages associated with toner cartridges.
Printer display message
Recommended action
It's a [X] toner cartridge problem. Check the user guide.
The cartridge is incompatible, or there is a connection error.
"X" indicates the cartridge causing the error.
주의:
Toner Cartridge Failure: [Error code] [X] toner cartridge is not installed. Install the cartridge.
The toner cartridge has failed.
Replace the toner cartridge.
Toner Cartridge Failure: [error code] Call for service.
The error code indicates which cartridge:
[X] toner cartridge is not compatible. Check the user guide.
The toner cartridge is not genuine, or there is a connection error.
[X] toner cartridge is not installed. Install it.
The cartridge is not installed or is installed incorrectly.
If this message occurs when a cartridge is installed, replace it.
[X] toner is low
The toner remaining in the cartridge may be insufficient for the current print job.
[X] toner is very low
There is no toner remaining. Prints may be blurry or completely lack the color.
