This document provides the procedures to remove and replace the separation roller assembly (500-sheet feeder).
Before performing service
Turn the printer power off
Disconnect the power cable.
warning:
Use the table below to identify the correct part number for your printer. To order the part, go to www.hp.com/buy/parts.
Separation roller assembly (550-sheet feeder) part number
RM2-5745-000CN
Required tools
No special tools are required to install this kit.
After performing service
Turn the printer power on
Connect the power cable.
Use the power switch to turn the power on.
Post service test
Make sure that the printer initializes to a Ready state.
Print a page from the accessory to make sure that the accessory is functioning correctly.
