348R4EA
HP Chromebook x360 12b-ca0002ns
Intel® Celeron® N4020 (1.1 GHz base frequency, up to 2.8 GHz burst frequency, 4 MB L2 cache, 2 cores)
Intel® Integrated SoC
4 GB LPDDR4-2400 MHz RAM (onboard)
Video graphics
Intel® UHD Graphics 600
64 GB eMMC
Optical drive
Optical drive not included
30.5 cm (12") diagonal, HD+ (1366 x 912), multitouch-enabled, IPS, edge-to-edge glass, micro-edge, 235 nits, 50% NTSC
Keyboard
Full-size, ceramic white keyboard
Intel® Wireless-AC 9560 802.11a/b/g/n/ac (2x2) Wi-Fi® and Bluetooth® 5 combo (Supporting Gigabit file transfer speeds)
1 microSD media card reader
2 USB 3.1 Gen 1 Type-C™ (5 Gb/s signaling rate, Power Delivery 3.0, DisplayPort™ 1.2); 1 USB 3.1 Gen 1 Type-A (Data Transfer Only); 1 headphone/microphone combo
27.2 x 21.6 x 1.73 cm
1.35 kg
45 W USB Type-C™ power adapter
2-cell, 40.31 Wh Li-ion polymer
HP Wide Vision 720p HD camera with integrated dual array digital microphones
Audio by B&O; Dual speakers
