4NK94AA
Display panel type
TN with LED backlight
24.5"
Panel active area (W x H)
54.37 x 30.26 cm
Resolution
FHD (1920 x 1080 @ 60 Hz)
Aspect ratio
16:9
Viewing angle (typical)
160° vertical; 170° horizontal
Brightness (typical)
400 cd/m²
Contrast ratio (typical)
1000:1 static
Response times
3 ms on/off; 1 ms (with overdrive)
Pixel pitch
0.283 mm
Display features
Anti-glare; Language selection; NVIDIA G-SYNC™; On-screen controls; Plug and Play; User controls; User programmable
