4L5S6EA
HP Spectre x360 Convertible 15-eb1007ur
Intel® Core™ i7-1165G7 (up to 4.7 GHz with Intel® Turbo Boost Technology, 12 MB L3 cache, 4 cores, 8 threads)
Intel® Integrated SoC
16 GB DDR4-2666 MHz RAM (onboard)
Video graphics
1 TB PCIe® NVMe™ TLC M.2 SSD
Optical drive
Optical drive not included
39.6 cm (15.6") diagonal, 4K UHD (3840 x 2160), multitouch-enabled, IPS, edge-to-edge glass, micro-edge, anti-reflection Corning® Gorilla® Glass NBT™, 400 nits, 100% sRGB
Intel® Wi-Fi 6 AX201 (2x2) and Bluetooth® 5 combo (Supporting Gigabit data rate)
1 microSD media card reader
2 Thunderbolt™ 4 with USB4™ Type-C® 40Gbps signaling rate (USB Power Delivery, DisplayPort™ 1.4, HP Sleep and Charge); 1 SuperSpeed USB Type-A 10Gbps signaling rate (HP Sleep and Charge); 1 HDMI 2.0b; 1 AC smart pin; 1 headphone/microphone combo
35.99 x 22.64 x 1.99 cm
Starting at 1.92 kg
90 W Smart AC power adapter
6-cell, 72.9 Wh Li-ion polymer
Battery life mixed usage
Up to 14 hours and 15 minutes
Video Playback Battery life
Up to 16 hours
HP True Vision 720p HD IR camera with integrated dual array digital microphones
Audio
Audio by Bang & Olufsen; Quad speakers; HP Audio Boost
