HP Notebook - 15-dw1050nl Product Specifications
1L6N1EA
Intel® Core™ i7-10510U (1.8 GHz base frequency, up to 4.9 GHz with Intel® Turbo Boost Technology, 8 MB L3 cache, 4 cores)
Intel® Integrated SoC
16 GB DDR4-2666 SDRAM (2 x 8 GB)
Video graphics
NVIDIA® GeForce® MX130 (2 GB GDDR5 dedicated)
512 GB PCIe® NVMe™ M.2 SSD
Optical drive
Optical drive not included
39.6 cm (15.6") diagonal FHD SVA anti-glare micro-edge WLED-backlit, 220 nits, 45% NTSC (1920 x 1080)
1 USB 3.1 Gen 1 Type-C™ (Data Transfer Only, 5 Gb/s signaling rate); 2 USB 3.1 Gen 1 Type-A (Data Transfer Only); 1 RJ-45; 1 AC smart pin; 1 HDMI 1.4b; 1 headphone/microphone combo
35.85 x 24.2 x 1.99 cm
Starting at 1.78 kg
65 W Smart AC power adapter
3-cell, 41 Wh Li-ion
HP TrueVision HD Camera with integrated dual array digital microphone
Dual speakers
Pre-installed software
Netflix
