If you want stop using a fingerprint, you can delete that fingerprint.
Option 1: Use only PIN, Password to unlock.
If you want to use only your backup screen lock methods, instead of your fingerprint:
Open the status area and click the settings icon
![](/wcc-assets/document/images/266/c06924530.gif)
On the left pane click People and then click Screen lock.
Enter your password, and then click Confirm.
Click Fingerprint.
To delete a fingerprint, click delete button
![](/wcc-assets/document/images/4/c06924536.gif)
The fingerprint is deleted, but you can set up the same fingerprint again.
Option 2: Remove screen lock device protection.
If you would rather not use a fingerprint, PIN, pattern, password:
huomautus:
It is strongly recommended to continue to lock your screen for security.
Open the status area and click the settings button
Toggle the disable button of Show lock screen when waking from sleep.
