This document applies to the following products:
- HP LaserJet Enterprise 500 MFP M525
- HP LaserJet Enterprise 500 color MFP M575
- HP OfficeJet Enterprise Color MFP X585
- HP Color LaserJet Enterprise MFP M680
- HP LaserJet Enterprise MFP M725
- HP LaserJet Enterprise 700 color MFP M775
- HP LaserJet Enterprise flow MFP M830
- HP Color LaserJet Enterprise flow MFP M880
When a 30.03.23 Error Alignment Calibration Failure appears on the control panel, it indicates there is an issue calibrating the scanner.
If there is also a copy or scan quality issue you will see a stripe of lines from the leading edge to the trailing edge of each page. A thin or wide stripe can appear in various positions on the page. The lines are parallel to the direction the original is fed into the scanner.
Kuva : Short-edge feed
Kuva : Long-edge feed
