Document ID: c04045903
Versio: 1
Advisory: HP Z1, Zx20 Workstations - 6 Beeps After Changing BIOS Settings
Notice: The information in this document, including products and software versions, is current as of the release date.The document is subject to change without notice.
Release date : 12-Dec-2013
Last updated : 12-Dec-2013
DESCRIPTION
HP Workstation boots with 6 beeps and no video following changes in the F10 setup utility.
Symptoms:
After changing and saving one of the following two settings in F10 setup:
1. Security / Secure Boot Configuration / Secure Boot -> Enabled
2. Advanced / Device Options / Video Option ROMS -> EFI
The system may produce 6 beeps on reboot, and will no longer show video on screen or load the operating system. There will appear to be no way to return to the F10 setup menu and change the settings back.
SCOPE
Systems:
  • HP Z1 Workstation
  • HP Z220 Convertible Minitower Workstation
  • HP Z220 Small Form Factor Workstation
  • HP Z420 Workstation
  • HP Z620 Workstation
  • HP Z820 Workstation
Operating Systems:
  • Non-OS Specific
RESOLUTION
The issue occurs because the video card ROM firmware is not UEFI compliant. When the system has been set to only boot using a UEFI compliant video ROM, and no UEFI compliant video ROM is available, the system is unable to activate the video card.
To resolve the issue, use the "Clear CMOS" button located on the system board. The exact location of the button varies slightly by workstation and is documented in the diagram on the inside of the side panel as well as in the service manual.
NOTE: Clearing CMOS will return all BIOS settings to default settings. Any customizations will need to be re-entered and saved.
Hardware platforms affected : HP Z1 Workstation, HP Z220 Convertible Minitower Workstation, HP Z220 Small Form Factor Workstation, HP Z420 Workstation, HP Z620 Workstation, HP Z820 Workstation
Support Communication Cross Reference ID : IA04045903
HP Inc. shall not be liable for technical or editorial errors or omissions contained herein. The information provided is provided "as is" without warranty of any kind. To the extent permitted by law, neither HP or its affiliates, subcontractors or suppliers will be liable for incidental, special or consequential damages including downtime cost; lost profits; damages relating to the procurement of substitute products or services; or damages for loss of data, or software restoration. The information in this document is subject to change without notice. HP Inc. and the names of HP products referenced herein are trademarks of HP Inc. in the United States and other countries. Other product and company names mentioned herein may be trademarks of their respective owners.
Muita tukivaihtoehtoja
