The printer is working, but the printed output is in black and white when it should be in color.
huomautus:If you have installed a refilled or remanufactured print cartridge, or a cartridge that has been used in another printer, the ink level indicator will be inaccurate or unavailable.
huomautus:You can also open the Printer Toolbox from the Print Properties dialog box. In the Print Properties dialog box, select Printing Preferences, click the Features tab, and then click Printer Services.
huomautus:A cartridge might be running out of ink even if the graphic shows that there is ink remaining in the cartridge. Lines or streaks always appear in printouts when the cartridges begin to run out of ink. Replace print cartridges that are out of ink or low on ink.
huomautus:If you are printing in reserve mode, without all the cartridges installed, the patterns associated with the missing cartridge will also be missing.
