Your computer features top-rated components. This chapter provides details about your components, where they are located, and how they work.
Component
(1)
Power light
(2)
Drive light
(3)
Memory card reader
Reads optional memory cards that enable you to store, manage, share, or access information.
To insert a card:
To remove a card:
(4)
USB port
Connects a USB device, such as a cell phone, camera, activity tracker, or smartwatch, and provides data transfer.
(5)
Optical drive
Depending on your computer model, reads an optical disc or reads and writes to an optical disc.
(6)
Optical drive eject button
Releases the optical drive disc tray.
(7)
Security cable slot
Attaches an optional security cable to the computer.
Poznámka: |
Component
(1)
Power connector
Connects an AC adapter.
(2)
AC adapter and battery light
(3)
RJ-45 (network) jack/status lights
Connects a network cable.
(4)
HDMI port
Connects an optional video or audio device, such as a high-definition television, any compatible digital or audio component, or a high-speed High-Definition Multimedia Interface (HDMI) device.
(5)
USB SuperSpeed ports (2)
Connect a USB device, such as a cell phone, camera, activity tracker, or smartwatch, and provide high-speed data transfer.
(6)
Audio-out (headphone)/Audio-in (microphone) combo jack
Connects optional powered stereo speakers, headphones, earbuds, a headset, or a television audio cable. Also connects an optional headset microphone. This jack does not support optional standalone microphones.
Varování: Poznámka: |
Component
(1)
WLAN antennas* (1 or 2 depending on model)
Send and receive wireless signals to communicate with wireless local area networks (WLANs).
(2)
Camera light
On: The camera is in use.
(3)
Camera
Allows you to video chat, record video, and record still images. Some cameras also allow a facial recognition logon to Windows, instead of a password logon..
Poznámka: |
(4)
Internal microphone
Records sound.
*The antennas are not visible from the outside of the computer. For optimal transmission, keep the areas immediately around the antennas free from obstructions.
For wireless regulatory notices, see the section of the Regulatory, Safety, and Environmental Notices that applies to your country or region.
To access this guide:
Component
(1)
TouchPad zone
Reads your finger gestures to move the pointer or activate items on the screen.
(2)
Left TouchPad button
Functions like the left button on an external mouse.
(3)
Right TouchPad button
Functions like the right button on an external mouse.
Component
(1)
Caps lock light
On: Caps lock is on, which switches the key input to all capital letters.
(2)
Mute light
Component
(1)
Power button
Upozornění: If the computer has stopped responding and shutdown procedures are ineffective, press and hold the power button down for at least 5 seconds to turn off the computer.
To learn more about your power settings, see your power options:
(2)
Speakers (2)
Produce sound.
(3)
Vent
Enables airflow to cool internal components.
Poznámka: |
Component
(1)
esc key
Displays system information when pressed in combination with the fn key.
(2)
fn key
Executes specific functions when pressed in combination with another key.
(3)
Windows key
Opens the Start menu.
Poznámka: |
(4)
Action keys
Execute frequently used system functions.
Poznámka: |
(5)
num lock key
Alternates between the navigational and numeric functions on the integrated numeric keypad.
(6)
Integrated numeric keypad
A separate keypad to the right of the alphabet keyboard. When num lock is pressed, the keypad can be used like an external numeric keypad.
Poznámka: |
Icon
Opens the “How to get help in Windows 10” webpage.
Decreases the screen brightness incrementally as long as you hold down the key.
Increases the screen brightness incrementally as long as you hold down the key.
Switches the screen image between display devices connected to the system. For example, if a monitor is connected to the computer, repeatedly pressing this key alternates the screen image from the computer display to the monitor display to a simultaneous display on both the computer and the monitor.
Turns the keyboard backlight off or on.
Poznámka: |
Mutes or restores speaker sound.
Decreases speaker volume incrementally while you hold down the key.
Increases speaker volume incrementally while you hold down the key.
Plays the previous track of an audio CD or the previous section of a DVD or a Blu-ray Disc (BD).
Starts, pauses, or resumes playback of an audio CD, a DVD, or a BD.
Plays the next track of an audio CD or the next section of a DVD or a BD.
Turns the airplane mode and wireless feature on or off.
Poznámka: Poznámka: |
Component
Vent
Poznámka: |
Poznámka:Check the following locations for the labels described in this section: the bottom of the computer, inside the battery bay, under the service door, on the back of the display, or on the bottom of a tablet kickstand.
Component
(1)
HP product name
(2)
Model number
(3)
Product ID
(4)
Serial number
(5)
Warranty period
