CUSTOMER GUIDE
Poly+ Support Service is designed to meet your organization’s most vital needs. Our Poly experts are available to assist you with any aspect of your covered solution.
Your continued satisfaction is our primary concern. With Poly Global Customer Support expert help is available no matter where in the world you are located. This Poly+ Support Services Customer Guide provides an overview of Poly+ and important information for your regional Poly Support Team, including parts replacement information. We advise you keep this information along with your product serial number in a convenient location. You will be asked for this information should you a need to contact Poly Global Customer Support.
We are committed to providing consistent, world-class service to help ensure you get the most from your Poly solution. Please do not hesitate to contact your local Poly Technical Support Center or visit us online athttps://www.poly.com/us/en/products/services/support if you have additional questions about our services portfolio.
Categories |
Features |
Poly+ |
STANDARD FEATURES |
Software upgrades and updates |
Aadvance Parts Replacement Next Business Day1 |
Escalation support - technical |
Poly Support Portal |
TECHNICAL SUPPORT |
24x7 |
Priority access |
Ecosystem cloud partner support |
POLY LENS PREMIUM FEATURES |
Notification Center |
Audit Log |
Network Diagnostics |
SUCCESS MANAGEMENT |
Customer Success Management (CSM) |
Optional |
Technical Account Management (TAM) |
Optional |
1Service Policy, Advance Parts Replacement Information.
For technical assistance, please contact your Poly Technical Support Center. You can submit a support case at poly.com/us/en/support. Please be ready to provide your products’ serial number.
The process defined on the next page is for Poly Branded Services. Please contact your Authorized Partner for support if you purchased a Partner Branded service.
When you contact our Poly Technical Support Center your support case will be logged. All cases are routed through our support process and escalated accordingly.
Our escalation process outlines how we respond to support cases reported to the Poly Technical Support Center. We prioritize the seriousness of each case and provide specific resolutions accordingly.
In some instances, additional support is required and the support case is escalated. Triggers for escalating cases may include one or more of the following:
Once escalated the assigned Engineer maintains support case ownership and works to resolve the issue.
Severity 1 (Critical) |
Severity 1 (Major) |
Severity 1 (Minor) |
This Severity Level shall indicate a sizable, wide-spread failure of a Product or Service that causes the Product, Service or related production network to be inoperative and that this inability to use the Product or Service has a critical effect on the Customer’s commercial operations. This severity level is generally characterized as a complete Product failure requiring immediate correction and for which no workaround is immediately available. |
This Severity Level shall indicate that the Product or Service is partially inoperable but is still usable by the Customer. The inoperative portion of the Product or Service severely restricts Customer’s commercial operations but has a less critical effect than a Severity Level 1 condition does. |
The Severity Level shall indicate that the Product or Service is usable with little or limited impact to the Customer and affects but does not severely restrict commercial operations. Any problem that does not impact the Customer’s production network shall be categorized at a maximum of this level. Errors in user interfaces, documentation, spelling, and other textual exclusions which do not cause or restrict usability of the Products will be categorized at this level. |
POLY +
Poly+ provides Customers with support for their Poly solutions. This service includes 24x7 priority technical phone support, advance hardware replacement with next business day parts shipment, access to major releases, patches, and hotfixes for current software updates and upgrades at: poly.com/support or via Poly Lens, exclusive discounts on selected professional services, and access to Poly’s Online Support Portal.
User location |
Regional parts depot location |
Deadline for same-day shipment of replacement parts |
United States |
United States |
6:00 p.m. Eastern time |
Canada |
Canada |
Brazil |
Brazil |
3:00 p.m. Sao Paulo time |
Chile |
Santiago |
2:00 p.m. Santiago time |
Colombia |
Bogota |
6:00 p.m. Bogota time |
Mexico |
Mexico City |
4:00 p.m. Mexico City time |
Rest of Central and South America |
United States |
France |
Netherlands |
4:00 p.m. Central European time |
Germany |
Netherlands |
South Africa |
Johannesburg |
3:00 p.m. South Africa time |
UK, Rest of Europe, Middle East and Africa |
Netherlands |
3:00 p.m. UK time |
Japan |
Tokyo |
3:00 p.m. Tokyo time |
New Zealand |
Sydney |
3:00 p.m. Sydney time |
India |
New Delhi |
3:00 p.m. New Delhi time |
Singapore |
Singapore |
3:00 p.m. Singapore time |
Thailand |
Singapore |
Hong Kong |
Singapore |
Indonesia |
Singapore |
China |
Beijing |
4:00 p.m. Beijing time |
Australia |
Sydney |
Taiwan |
Singapore |
Rest of Asia-Pacific region |
Singapore |
All field engineer (FE) requests will be supported during standard 8x5 business hours, including parts replacement and FE onsite arrival. For example, if a Return Materials Authorization (RMA) and SVO is created on Monday, the part and the FE will arrive during the next business day. The deadline for same day processing is generally 3 p.m. local time to Poly’s regional parts depot.
CRT, LCD and plasma displays require two business days for RMA processing. All other RMA transactions wll be processed by Poly and express shipped same-day when the order is placed before the specified time. Actual arrival time of replacement part may be delayed due to customs or other local conditions.
The following matrix below shows when the Courier or Tax and duties fees are the responsibility of Poly or the Customer.
Shipping terms and transit times may be found at:
Situation |
Service level |
Courier part outbound |
Courier part inbound |
Tax and duties outbound |
Tax and duties inbound |
Dead on Arrival (DOA) |
Advance exchange |
Yes |
Yes |
Yes |
Yes |
Support contract |
Advance exchange |
Yes |
Yes |
No |
Yes |
In warranty |
Return to factory repair |
Yes |
Yes |
No |
Yes |
Out of warranty/chargeable |
Yes |
No |
No |
Yes |
Advance exchange |
Yes |
Yes |
No |
Yes |
Worldwide terms and conditions |
