note:HP continually improves and changes product parts. For complete and current information on supported parts for your computer, go to http://partsurfer.hp.com, select your country or region, and then follow the on-screen instructions.
note:Details about your computer, including model, serial number, product key, and length of warranty, are on the service tag at the bottom of your computer. See Labels for details.
Figure : Computer major components
Item
Spare part number
Display panel assembly
note: | ||
(1)
Touch
not spared
(2)
Non-touch
not spared
(3)
Top cover/keyboard (includes cable)
note: | |
No backlight
L44548-xxx
Backlit
L44547-xxx
(4)
RTC battery
L02772-001
(5)
TouchPad (includes cable)
L44538-001
(6)
Power connector cable
L01048-001
(7)
Fingerprint sensor assembly
note: |
L44516-001
(8)
Card reader board (includes cable)
note: |
L44537-001
(9)
Power/USB board
note: |
L44536-001
(10)
Speaker assembly
L44513-001
(11)
Fan
L44514-001
(12)
Heat sink (includes replacement thermal material)
L44512-001
(13)
System board (includes integrated processor and replacement thermal material)
All system boards use the following part numbers:
xxxxxx-001: Non-Windows operating system
xxxxxx-601: Windows 10 operating system
Intel Core i7-8565U processor
L44507-xxx
Intel Core i5-8365U processor
L44506-xxx
Intel Core i5-8265U processor (for use in models with WWAN)
L44505-xxx
L44504-xxx
Intel Core i3-8145U processor (for use in models with WWAN)
L44503-xxx
L44502-xxx
Intel Pentium 5405U processor
L44508-xxx
Intel Celeron 4255U processor
L44501-xxx
(14)
USB bracket
note: |
L44545-001
(15)
Memory modules (DDR4-2400)
16 GB
865396-850
8 GB
862398-850
4 GB
862397-850
(16)
M.2 solid-state drive
512 GB, PCIe, TLC
L44529-001
256 GB, PCIe
L44528-001
256 GB, SATA-3, TLC
L44527-001
128 GB, SATA-3, TLC
L46736-001
16 GB, PCIe (Optane memory module)
L44526-001
(17)
WLAN module
Intel Dual Band Wireless-AC 9560 802.11ac 2 × 2 Wi-Fi + Bluetooth 5.0 Combo Adaptor (non-vPro)
L22634-001
Realtek RTL8822BE 802.11AC 2 × 2 Wi-Fi + Bluetooth 4.2 combination adapter
915623-001
(18)
WWAN module
Intel XMM 7360 LTE-Advanced
L15398-001
Intel XMM 7262 LTE-Advanced (Cat6)
L35286-001
(19)
Battery
L32656-002
(20)
1 TB, 5400 rpm, 7 mm
762990-001
500 GB, 7200 rpm, 7 mm
703267-001
Hard Drive Hardware Kit, includes:
L44510-001
(21)
Hard drive cable
(22)
Hard drive cover
(23)
Bottom cover
L44515-001
