Figure : The Clivia motherboard
Processor
TDP
Integrated Graphics
AMD A9-9425 3.1 GHz, Dual Core
15 W
AMD Radeon R5 Graphics
note:32-bit systems cannot address a full 4.0 GB of memory.
note:Maximum memory shown reflects the capability of the hardware and can be limited further in the operating system.
note:Integrated video is not available if a graphics card is installed.
note:Integrated audio is not available if a sound card is installed.
note:The configuration might vary depending on your model (for example, if a dedicated graphics card is included). Any modifications or upgrades might change the configuration, port accessibility, and port functionality.
Figure : Clivia back I/O panel Audio: Line in Audio: Line out Audio: Microphone DC power-in HDMI out VGA out RJ45 Ethernet USB 2.0: 2 USB 3.1: 2
