Figure : The Tampa2 motherboard
Processor
TDP
Integrated Graphics
Intel Core i7-8700K (Coffeelake) 3.7 GHz, Hexa Core
95 W
Integrated HD Graphics 630
Intel Core i7-8700 (Coffeelake) 3.7 GHz, Hexa Core
65 W
Intel Core i5-8400 (Coffeelake) 2.8 GHz, Hexa Core
65 W
note:32-bit systems cannot address a full 4.0 GB of memory.
note:Maximum memory shown reflects the capability of the hardware and can be limited further in the operating system.
note:Integrated video is not available if a graphics card is installed.
note:The motherboard supports 5.1 surround sound. If the computer does not have the required audio jacks for a 5.1 configuration, additional hardware is required to use 5.1 surround sound.
note:An internal speaker is not included with integrated audio. External speakers or headphones are required to hear sound.
note:Integrated audio is not available if a sound card is installed.
note:The configuration might vary depending on your model (for example, if a dedicated graphics card is included). Any modifications or upgrades might change the configuration, port accessibility, and port functionality.
Figure : Tampa2 back I/O panel Optical SPDIF connector DisplayPort HDMI out USB 2.0: 2 USB 3.1: 4 LAN (Ethernet) Audio: Line in Audio: Line out Audio: Microphone
