Use the following procedure to clear jams in the output bin. When a jam occurs, the control panel might display a message and an animation that assists in clearing the jam.
13.E1.XX Jam at standard output bin
If paper is visible in the output bin, grasp the leading edge and gently remove it.Figure : Remove the jammed paper
