Use the following procedure to clear jams in the fuser. When a jam occurs, the control panel displays a message and an animation that assists in clearing the jam.
13.B9.AZ Fuser area jam
13.B9.CZ Fuser wrap jam
13.B9.DD Fuser area jam (top cover)
caution:The fuser can be hot while the printer is in use. Wait until it cools before attempting to clear a jam in the fuser area.
Open the fuser door on the left side of the printer.Figure : Open the fuser door
Push down on the green tab to open the fuser jam-access cover.Figure : Open the fuser jam-access cover
Remove any jammed paper from the fuser.Figure : Remove jammed paper from the fuser
Close the fuser jam-access cover.Figure : Close the fuser jam-access cover
Close the fuser door.Figure : Close the fuser door
