The HP 24ea is a 60.5 cm (23.8 in) IPS Display.
Figure : HP 24ea IPS Display
LED feature
Specification
Display size
60.5 cm (23.8 in) diagonal
Display type
IPS with LED backlight
Panel active area
52.7 x 29.6 cm (20.7 x 11.7 in)
Scan range
Horizontal: 30 to 80 KHz
Vertical: 50 to 60 Hz
Brightness
250 nits
Color support
Up to 16.7 million colors with the use of FRC technology
Color gamut
72%
Pixel pitch
0.2745 (H) mm x 0.2745 (V) mm
93 PPI
Inputs
1 VGA
1 HDMI
Audio in/Audio out
HDCP support
Viewing angle
Horizontal viewing angle (typical): 178 degrees
Vertical viewing angle (typical): 178 degrees
Recommended resolution (H x V)
1920 x 1080 @ 60 Hz (Full HD)
Aspect ratio
16:9
Static contrast ratio
1000:1
Dynamic contrast ratio
10,000,000:1
Response time
6 ms GtG w/OD
14 ms GtG (typ) / 28 ms GtG (Max)
Power supply
External
Power consumption
30 Watts max
Tilt
-5 to +25 degrees
Dimensions
W x D x H (unpacked):
54.1 x 18.3 x 40.9 cm (21.3 x 7.2 x 16.1 in)
Unpacked: 3.1 Kg (6.8 lbs)
