On occasion, when trying to access the cartridges, you might encounter a temporary issue where the print bar is stuck in the down position. When the print bar is in the down position, you will not be able to access the cartridges.
note:This video shows an HP OfficeJet Pro X printer, however, the same steps apply to the HP PageWide Pro printers.
