This document is for the HP Scitex FB500 and FB700 printers.
note:Changing the BIOS does not require any special skills or knowledge, but navigating through the screens of the Setup Utility may be unfamiliar to some printer operators. If a qualified person who is knowledgeable and experienced with BIOS configuration of standard desktop PCs is available, that person may be able to perform the required configuration more quickly.
note:Do NOT remove the service-end enclosure for this procedure.
caution:The preceding table lists only the settings in the BIOS setup that require changes. Settings that are not listed should be left at their default setting. HP recommends that no other changes be made that are NOT specified in the table.changes may have occurred in the BIOS supplied motherboard manufacturer since the publication of this document. If a line item is listed in the table, but cannot be found in the BIOS setup utility, disregard that item and continue to the next item.
BIOS Setup Feature
Custom Setting (change BIOS to this)
CMOS Features > Halt On
No Errors
Advanced BIOS Features > CPU Features > PPM Mode
SMM
Advanced BIOS Features > CPU Features > C1E Function
Disabled
Advanced BIOS Features > CPU Features > Execute Disable Bit
Disabled
Advanced BIOS Features > CPU Features > Core Multi-Processing
Disabled
Advanced BIOS Features > Second Boot Device
Disabled
Advanced BIOS Features > Third Boot Device
Disabled
Advanced BIOS Features > Boot Other Device
Disabled
Advanced BIOS Features > APIC Mode
Disabled
Advanced BIOS Features > ASF Support
Disabled
Advanced BIOS Features > DMI Event Log
Disabled
Advanced Chipset Features > System BIOS Cacheable
Disabled
Advanced Chipset Features > PCI Express Root Port Func > PCI Express Port 1
Disabled
Advanced Chipset Features > PCI Express Root Port Func > PCI Express Port 2
Disabled
Advanced Chipset Features > PCI Express Root Port Func > PCI Express Port 3
Disabled
Advanced Chipset Features > PCI Express Root Port Func > PCI Express Port 4
Disabled
Advanced Chipset Features > PCI Express Root Port Func > PCI Express Port 5
Disabled
Advanced Chipset Features > PCI Express Root Port Func > PCI Express Port 6
Disabled
Advanced Chipset Configuration > On- Chip Frame Buffer Size
32MB
Advanced Chipset Configuration > Total GFX Memory
128MB*
Integrated Peripherals > OnChip IDE Device > On-Chip Secondary PCI IDE
Disabled
Integrated Peripherals > Onboard Device > Audio Amplifier
Disabled
Integrated Peripherals > Onboard Device > Azalia Controller
Disabled
Integrated Peripherals > Super IO Device > Onboard FDC Controller
Disabled
Integrated Peripherals > Super IO Device > Onboard Serial Port 2
Disabled
Integrated Peripherals > Super IO Device > Onboard Parallel Port
Disabled
Integrated Peripherals > Super IO Device > PWRON After PWR-Fail
On
Integrated Peripherals > USB Device Setting > USB 1.0 Controller
Disabled
Integrated Peripherals > USB Device Setting > USB 2.0 Controller
Disabled
Integrated Peripherals > USB Device Setting > USB Operation Mode
Disabled
Integrated Peripherals > USB Device Setting > USB Keyboard Function
Disabled
Integrated Peripherals > USB Device Setting > USB Mouse Function
Disabled
Integrated Peripherals > USB Device Setting > USB Storage Function
Disabled
Power Management Setup > Modem Use IRQ
NA
PnP/PCI Configurations > Init Display
Onboard
PnP/PCI Configurations > Resources Controlled By
Manual
PnP/PCI Configurations > IRQ Resources > IRQ-7 assigned to
Reserved
PnP/PCI Configurations > IRQ Resources > IRQ-9 assigned to
Reserved
Frequency/Voltage Control > Auto Detect PCI Clk
Disabled
