HP provides HP Wireless Direct and NFC (Near Field Communication) in this printer which enables printing from a wireless mobile device directly to an HP Wireless Direct enabled printer without requiring a connection to a network or the Internet.
The NFC capabilities enable an easy one-to-one Wireless Direct print connection for mobile devices via a simple device-to-device touch. Go to the product support home page for this product for more information:
In the US, go to www.hp.com/support/colorljMFPM476.
Outside the US, go to www.hp.com/support. Select your country/region. Click Troubleshooting. Enter the product name, and then select Search.
Then, from the product's support home page, select Tasks, Setup & Install, Mobile Printing.
Use HP Wireless Direct to print wirelessly from the following devices:
iPhone, iPad, or iPod touch using Apple AirPrint or the HP ePrint app
Android mobile devices using the HP ePrint App or the Android embedded print solution
Symbian mobile devices using the HP ePrint Home & Biz App
PC and Mac devices using the HP ePrint Software
For more information on HP Wireless Direct printing, go to www.hp.com/go/wirelessprinting, and then click HP Wireless Direct on the left navigation bar.
NFC and HP Wireless Direct capabilities can be enabled or disabled from the printer’s control panel.
From the Home screen on the product control panel, touch the Wireless
button.
Open the following menus:
Wireless Menu
Wireless Direct Settings
Wireless Direct On/Off
Touch the On menu item.
