From the front panel, turn the power off then on.
Check the front-panel display message, if it shows the ready message, the printer is ready to print. If the problem remains continue with the next step.
Remove the printhead, see Remove a printheadRemove a printhead.
Clean the electrical connections on the backside of the printhead with a lint free cloth. You can carefully use a mild rubbing alcohol if moisture is needed to remove residue. Do not use water.
This is a delicate process and may damage the printhead. Do not touch the nozzles on the bottom side of the printhead, especially not with any alcohol.Figure : Cleaning the printhead electrical connections -
Reinsert the printhead, see Insert a printheadInsert a printhead.
Check the front-panel display message. If the problem remains, try a new printhead.
