During normal use of the product, an 'Unsupported Personality: PCL' error page prints.
note:If you closed the Download Complete screen, browse to the folder where you saved the .exe file, and then click it.
Recommended
Custom
For full use of all your product features: This installation provides full product functionality. HP also includes valuable software to help you get the most out of your product.
This installation type is designed to work for most users.
A custom type of installation might be available for your product. This installation allows you to install the minimum software required or the preferred software.
Use this type of installation only if the computer is low on hard disk space or you attempted a recommended type of installation and received errors. (Try to fix any errors before starting a custom installation.)
caution: |
