1
HP Deskjet 6940 series product
2
Optional: Automatic Two-Sided Printing Accessory
3
Optional: 250-Sheet Plain Paper Tray
4
Power Supply
5
Power cord
6
Ethernet cable
7
Tri-color cartridge
8
Black cartridge
9
Reference Guide
10
Network guide
11
Setup guide
12
Product software CD
note:If these accessories did not ship with the product, you can buy them from an authorized HP dealer. The accessories are not available in all countries/regions.
note:Do not discard the rear access door. The product cannot print unless the access door is in place.
caution:Do not touch the cartridge ink nozzles or copper contacts. Touching these parts can result in clogs, ink failure, and bad electrical connections. Do not remove the copper strips. The strips are required electrical contacts.
