Control panel message
Recommended action
10.32.00 UNAUTHORIZED SUPPLY IN USE
The product is using a non-HP supply.
If you believe you purchased a genuine HP supply, go to http://www.hp.com/go/anticounterfeit. Any product repair required as a result of using non-HP or unauthorized supplies is not covered under warranty. HP cannot ensure the accuracy or the availability of certain features.
10.90.XY REPLACE <COLOR> CARTRIDGE
A toner replenishment malfunction has occurred.
Replace the print cartridge.
10.91.99 PRINT CARTRIDGE ERROR
One of the cyan, magenta, or yellow print cartridges is defective and needs to be replaced.
After replacing the defective cartridge, turn the power off then on to continue.
10.XX.YY SUPPLY MEMORY ERROR
The product cannot read or write to at least one print cartridge memory tag or a memory tag is missing from a print cartridge.
XX values
YY values
Reinstall the print cartridge, or install a new print cartridge.
11.XX Internal clock error
To continue press OK
The product real time clock has experienced an error.
Whenever the product is turned off and then turned on again, set the time and date at the control panel. See Use the control panel.
If the error persists, you might need to replace the formatter.
13.XX.YY FUSER AREA JAM
A jam has occurred in the fuser area.
For instructions on clearing the jam, see Clear jams in the right door.
13.XX.YY FUSER WRAP JAM
A jam has occurred in the fuser.
To prevent this jam in the future, set the print optimization mode LIGHT MEDIA to ON. See Print Quality menu.
13.XX.YY JAM ABOVE TOP OUTPUT BIN
A jam has occurred in the output area.
For instructions on clearing the jam, see Clear jams in the output bin area.
13.XX.YY JAM IN LOWER RIGHT DOOR
A jam has occurred in the lower right door (Tray 3).
For instructions on clearing the jam, see Clear jams in the lower right door (Tray 3).
13.XX.YY JAM IN RIGHT DOOR
A jam has occurred in the duplex and feed area inside the right door.
13.XX.YY JAM IN TRAY 1
A jam has occurred in Tray 1.
For instructions on clearing the jam, see Clear jams in Tray 1.
13.XX.YY JAM IN TRAY 3
A jam has occurred in the indicated tray.
For instructions on clearing the jam, see Clear jams in Tray 2 or Clear jams in the optional 500-sheet paper and heavy media tray (Tray 3).
13.XX.YY JAMS IN RIGHT DOOR
20 INSUFFICIENT MEMORY
The product received more data than can fit in the available memory. You might have tried to transfer too many macros, soft fonts, or complex graphics.
Press the OK button to print the transferred data (some data might be lost), and then simplify the print job or install additional memory.
22 EIO X BUFFER OVERFLOW
Too much data was sent to the EIO card in the specified slot (x). An incorrect communications protocol might be in use.
Press the OK button to print the transferred data. (Some data might be lost.)
Check the host configuration. If this message persists, contact an HP-authorized service or support provider. (See the HP support flyer, or go to www.hp.com/support/cljcp3525.)
22 EMBEDDED I/O BUFFER OVERFLOW
Too much data was sent to the embedded HP Jetdirect print server.
22 USB I/O BUFFER OVERFLOW
The product's USB buffer has overflowed.
If the message persists, contact HP Support at www.hp.com/support/cljcp3525.
40 EIO X BAD TRANSMISSION
The connection between the product and the EIO card in the specified slot has been broken.
Press the OK button to clear the error message and continue printing.
Try to reinstall the EIO card.
40 EMBEDDED I/O BAD TRANSMISSION
A temporary printing error has occurred.
Press the OK button to clear the error message. (Data will be lost.)
41.3 UNEXPECTED SIZE IN TRAY <X>
LOAD TRAY <X> [TYPE] [SIZE]
To use another tray press OK
The product detected a different paper size than expected.
The prompt to use another tray is displayed only if another tray has paper loaded.
Load the tray with the size and type of paper indicated, or use another tray.
41.5 UNEXPECTED TYPE IN TRAY <X>
The product detected a different paper type than expected.
Load the tray with the size and type of paper indicated, or use another tray if available.
41.7 ERROR
Try using different paper.
If the error does not clear, turn the product off and then on.
48.01 TRANSFER UNIT ERROR
The transfer belt has dislocated during printing.
Turn product off then on.
49.XXXX ERROR
To continue turn off then on
A firmware error has occurred.
This error can be caused by corrupted print jobs, software applications issues, non-product specific printer drivers, poor-quality USB or network cables, bad network connections or incorrect configurations, invalid firmware operations, or unsupported accessories.
50.X FUSER ERROR
A fuser error has occurred.
Make sure you have the correct fuser. Re-seat the fuser. Turn the product off, and then turn the product on.
If this message persists, contact an HP-authorized service or support provider. (See the HP Support flyer, or go to www.hp.com/support/cljcp3525.)
51.XY ERROR
51.XY ERROR
A printer error has occurred.
Turn power off then on.
52.XY ERROR
54.XX ERROR
Error requires that the product be turned off then on.
55.XX.YY DC CONTROLLER ERROR
The print engine is not communicating with the formatter.
56.X ERROR
57.XX ERROR
58.XX ERROR
59.BO CLEANING MOTOR ERROR
REPLACE TONER COLLECTION UNIT
This message appears for one of the following reasons:
Replace the toner collection unit. See Change the toner collection unit.
59.XY ERROR
60.X ERROR
The tray specified by X is not lifting correctly.
X values
Follow the instructions on the product control panel.
62 NO SYSTEM
The product has an internal problem.
Turn the product off and then on.
66.XY.ZZ SERVICE ERROR
Check cables and turn off then on
The external paper-handling controller has detected a failure.
68.X PERMANENT STORAGE FULL
The product NVRAM is full. Some settings saved in the NVRAM might have been reset to the factory defaults. Printing can continue, but some unexpected functions might occur if an error occurred in permanent storage.
X values
Press the OK button to clear the message. If the message is not cleared, turn the product off, and then turn the product on.
68.X PERMANENT STORAGE WRITE FAIL
The product NVRAM is failing to write. Printing can continue, but some unexpected functions might occur if an error occurred in permanent storage.
X values
68.X STORAGE ERROR SETTINGS CHANGED
One or more product settings are invalid and have been reset to the factory-default settings. Printing can continue, but some unexpected functions might occur if an error occurred in permanent storage.
69.X ERROR
A temporary printing error occurred.
79.XXXX ERROR
An internal product error has occurred.
If the message persists, contact HP support. See Customer support.
8X.YYYY EIO ERROR
This message appears in English only. It indicates that the EIO card in slot X has failed.
Replace the EIO card.
8X.YYYY EMBEDDED JETDIRECT ERROR
This message appears in English only. It indicates that the embedded HP Jetdirect card has failed.
Contact HP support. See Customer support.
Access denied MENUS LOCKED
The control-panel menu that you tried to select is currently locked.
Consult with the person who administers the product.
Action not currently available for tray x Tray size cannot be ANY SIZE/ANY CUSTOM
Duplex registration is not available when the size is set to ANY SIZE or ANY CUSTOM.
Configure the tray to a specific size, and then set the registration for that tray.
BAD OPTIONAL TRAY CONNECTION
The optional tray is not connected.
If the error persists, contact an HP-authorized service or support provider. See the HP support flyer, or go to www.hp.com/support/cljcp3525
Calibrating...
Displays during calibration.
No action is necessary.
CALIBRATION RESET PENDING
Processing...
A calibration reset will occur when all jobs are processed.
To begin the reset sooner, cancel all jobs by pressing the Stop button
Canceling...
The product is canceling the current job.
CARD SLOT <X> NOT FUNCTIONAL
The compact flash card in slot <X> is not working correctly.
Remove the card from the slot indicated, and replace with a new card.
CARD SLOT DEVICE FAILURE
To clear press OK
The specified device has failed.
Press the OK button to clear.
CARD SLOT FILE OPERATION FAILED
To clear press OK
A PJL file system command attempted to perform an illogical operation.
CARD SLOT FILE SYSTEM IS FULL
To clear press OK
A PJL file system command could not store something on the file system because the file system was full.
CARD SLOT IS WRITE PROTECTED
To clear press OK
The file system device is protected and no new files can be written to it.
CARD SLOT NOT INITIALIZED
This file-storage component must be initialized before use.
Use the embedded Web server or HP Web Jetadmin to initialize the component.
CARTRIDGES IN WRONG POSITIONS
Two or more print-cartridge slots contain the wrong color print cartridge.
From left to right, the print cartridges should be installed in this order:
Install the correct color cartridge in each slot.
CHECKING PAPER PATH
The product is checking for possible paper jams.
CHECKING PRINTER
The product is conducting an internal test.
CHOSEN PERSONALITY NOT AVAILABLE
A print job requested a product language (personality) that is not available for this product. The job will not print and will be cleared from memory.
Print the job by using a printer driver for a different printer language, or add the requested language to the product (if possible). To see a list of available personalities, print a configuration page. (See Information pages.)
CLEANING DISK <X>% COMPLETE
Do not power off
The product is cleaning the hard disk or a compact flash disk.
Do not turn off. The product will automatically restart when cleaning is complete. Product functions are unavailable.
CLEANING...
The product is performing an automatic cleaning cycle. Printing will continue after the cleaning is complete.
CLEARING EVENT LOG
This message is displayed while the event log is cleared. The product will exit the menus once the event log has been cleared.
CLEARING PAPER PATH
The product is attempting to eject jammed paper.
Check progress at the bottom of the display.
CLOSE RIGHT DOOR
A door on the right side of the product is open.
Cooling engine
The product is cooling.
Creating...
CLEANING PAGE
A cleaning page is being generated.
DATA RECEIVED
To print last page press OK
The product is waiting for the command to print the last page.
Press the OK button to print the last page.
DATE/TIME = YYYY/MMMM/DD HH:MM
To change press OK
To skip press
The current date and time set for the product.
Press the OK button to set the date and time or press the stop button
Deleting private jobs
The product is deleting a private stored job.
Deleting...
The product is currently deleting the stored job.
EIO <X> DISK INITIALIZING
The specified EIO disk device is initializing.
EIO <X> DISK NOT FUNCTIONAL
The EIO disk in slot <X> is not working correctly.
EIO <X> DISK SPINNING UP
EIO disk device in slot <X> is spinning up its platter. Jobs that require disk access must wait.
EIO DEVICE FAILURE
To clear press OK
EIO FILE OPERATION FAILED
To clear press OK
EIO FILE SYSTEM IS FULL
To clear press OK
EIO IS WRITE PROTECTED
To clear press OK
EIO NOT INITIALIZED
Event log empty
No product events are in the log.
EXPECTED DRIVE MISSING
The product cannot find an external hard drive.
Insert the hard drive or see the embedded Web server for more information.
Genuine HP cartridge installed
You have installed a new print cartridge that was manufactured by HP.
Genuine HP supplies installed
You have installed more than one new print cartridge that was manufactured by HP.
HP ENCRYPTED DRIVE DISABLED
The drive has been encrypted for another product.
Remove the drive or see the embedded Web server for more information.
INCOMPATIBLE <COLOR> CARTRIDGE
The indicated color print cartridge is not compatible with this product.
Replace the print cartridge with one that is designed for this product.
INCOMPATIBLE FUSER
The incorrect fuser was installed.
INCOMPATIBLE SUPPLIES
Print cartridges or other supply items are installed that were not designed for this product. The product cannot print with these supplies installed.
Install supplies that are designed for this product.
Incorrect
The PIN is incorrect.
Use the up arrow
Initializing
The product is starting.
No action is necessary. Please wait until the Ready message appears on the display.
Initializing permanent storage
Displayed when the product is turned on to show that permanent storage is being initialized.
Insert or close tray <X>
The indicated tray is open, and it is interfering with paper being fed from another tray.
Close the tray so that printing can continue.
INSTALL <COLOR> CARTRIDGE
The print cartridge has been removed or has been installed incorrectly.
Replace or reinstall the print cartridge correctly to continue printing. See Change print cartridges.
INSTALL FUSER
The fuser has been removed or installed incorrectly.
INSTALL SUPPLIES
For status press OK
Press the OK button to identify which supplies need to be replaced. Press the OK button a second time for more information about the specific supply.
Insert the supply item or make sure the installed supply item is fully seated.
INSUFFICIENT MEMORY TO LOAD FONTSDATA
The product does not have enough memory to load the data (for example, fonts or macros) from the location specified.
To continue without this information press the OK button . If the message persists, add more memory.
LOAD TRAY 1 [TYPE] [SIZE]
The indicated tray is loaded and configured for a type and size other than the one specified in the job.
LOAD TRAY 3 [TYPE] [SIZE]
Media insert required in tray
This message appears when printing 4 x 6 in or 100 x 150 mm size paper, which requires the HP postcard media insert in Tray 3.
Install the HP postcard media insert in Tray 3, and load the requested paper.
This message appears when the indicated tray is selected but is not loaded, and no other paper trays are available for use.
Load the tray with requested paper and then press the OK button to continue.
This message appears when the indicated tray is selected but is not loaded, and other paper trays are available for use.
LOADING PROGRAM <XX>
Do not power off
Programs and fonts can be stored on the product’s file system and are loaded into RAM when the product is turned on. The number XX specifies a sequence number indicating the current program being loaded.
No action necessary. Do not turn the product off.
MANUALLY FEED <TYPE> <SIZE>
This message appears when Tray 1 is selected but is not loaded, and other paper trays are available for use.
Load tray with requested paper. If paper is already in tray, press the help button
To override the message, press the OK button to use a type and size of paper that is available in another tray.
The specified job requires a manual feed.
MANUALLY FEED OUTPUT STACK
Then press OK to print second side
The product has printed the first side of a manual duplex job and is waiting for the user to insert the output stack to print the second side.
MOVING SOLENOID
To exit press
The solenoid is moving as part of a component test.
MOVING SOLENOID AND MOTOR
To exit press
The solenoid and a motor are moving as part of a component test.
No job to cancel
You have pressed the stop button
No stored jobs
Displayed when the user enters the RETRIEVE JOB menu and there are no jobs to retrieve.
NON HP SUPPLY IN USE
A non-HP supply is in use.
A user authorized the use of non-HP supplies when the HP supply was replaced. Any product repair required as a result of using non-HP or unauthorized supplies is not covered under warranty. HP cannot ensure the accuracy or the availability of certain features.
NON HP SUPPLY INSTALLED
If you believe you purchased a genuine HP supply, go to www.hp.com/go/anticounterfeit. Any product repair required as a result of using non-HP or unauthorized supplies is not covered under warranty. HP cannot ensure the accuracy or the availability of certain features.
ORDER <COLOR> CARTRIDGE
The identified print cartridge is nearing the end of its estimated useful life.
Printing will continue until a supply needs to be replaced.
Order a replacement print cartridge.
LESS THAN XXXX PAGES
The identified cartridge is nearing the end of its estimated useful life. Estimated pages remaining is based upon the historical page coverage of this product.
Order a replacement cartridge.
ORDER FUSER KIT
The fuser is near end of life. The product is ready and will continue for the estimated number of pages indicated. Printing will continue until a supply needs to be replaced.
Order a replacement fuser kit.
ORDER SUPPLIES
More than one supply is nearing the end of its estimated useful life.
Order the necessary supplies.
ORDER TONER COLLECTION UNIT
The toner collection unit is nearly full.
Order a replacement toner collection unit now. Printing can continue.
Paused
To return to Ready press
The product is paused, and there are no error messages pending at the display. The I/O continues receiving data until memory is full.
Press the stop button
Performing upgrade
<X:YYY> % complete
Do not power off
The product is in the process of upgrading the firmware.
Please wait until the upgrade is complete.
Performing... COLOR BAND TEST
The color-band test is being performed.
Performing... PAPER PATH TEST
The product is performing a paper path test.
Please wait
The product is in the process of clearing data.
Powering off...
The product is shutting down.
Please wait until the product shuts down.
Printing <REPORT>
The product is printing an internal page. The product will return to the online Ready state when the page is completed.
PRINTING STOPPED
Time has expired on the Print/Stop test.
Press the OK button to continue.
Processing duplex job
Do not grab paper until job completes
Paper temporarily comes into the output bin while printing a duplex job. Do not attempt to remove the pages until the job is complete.
Do not grab paper as it temporarily comes into the output bin. The message will disappear when the job is finished.
Processing...
The product is currently processing a job but is not yet picking pages. When paper motion begins, this message will be replaced by a message that indicates which tray the job is being printed from.
Processing...
CLEANING PAGE
The product is processing a cleaning page.
Processing... copy <X> of <Y>
The product is currently processing or printing collated copies. The message indicates that copy X of Y total copies is currently being processed.
Processing... from tray <X>
The product is actively processing a job from the designated tray.
RAM DISK DEVICE FAILURE
To clear press OK
RAM DISK FILE OPERATION FAILED
To clear press OK
RAM DISK FILE SYSTEM IS FULL
To clear press OK
RAM DISK IS WRITE PROTECTED
To clear press OK
RAM DISK NOT INITIALIZED
Ready
The product is online and ready for data. No status or product attendance messages are pending at the display.
Ready
IP ADDRESS
The product is online and ready.
Ready Diagnostics mode
To exit press
The product is in Diagnostics mode.
To stop Diagnostic mode, press the Stop button
Receiving Upgrade
A firmware upgrade is in progress.
Do not turn the product off until the product returns to Ready.
Remove all print cartridges
To exit press
The product is testing the transfer unit assembly.
To perform the test, remove all the print cartridges. To cancel the test, press the stop button
Remove at least one print cartridge
To exit press
The product is testing the print-cartridge motor.
To perform the test, remove at least one print cartridge. To cancel the test, press the stop button
The product indicates when a supply level is at its estimated end of life. The actual life remaining might be different than the estimation. Have a replacement supply available to install when print quality is no longer acceptable. The supply does not need to be replaced now unless the print quality is no longer acceptable. After an HP supply has reached its approximated end of life, HP’s premium Protection Warranty on that supply ends. You can configure the product to continue printing by using the REPLACE SUPPLIES menu. For more information about the REPLACE SUPPLIES menu, see System setup menu.
Replace the specified color cartridge. Change print cartridges
Or, configure the product to continue printing by using the REPLACE SUPPLIES menu. For more information about the REPLACE SUPPLIES menu, see System setup menu.
REPLACE FUSER KIT
The fuser is nearing the end of its useful life. Printing can continue.
REPLACE FUSER KIT
The REPLACE SUPPLIES menu is set to the STOP AT LOW setting. The fuser kit has reached the low threshold.
Press the OK button to continue printing until the fuser reaches the end of life, or replace the fuser now.
Replace the fuser
REPLACE SUPPLIES
For status press OK
Two or more supplies are at the estimated end of life. The actual life remaining might be different than the estimation. Have a replacement supply available to install when print quality is no longer acceptable. The supply does not need to be replaced now unless the print quality is no longer acceptable. After an HP supply has reached its approximated end of life, HP’s premium Protection Warranty on that supply ends. You can configure the product to continue printing by using the REPLACE SUPPLIES menu. For more information about the REPLACE SUPPLIES menu, see System setup menu.
Press the OK button to see which supplies need to be replaced.
REPLACE SUPPLIES
Pages remaining for at least two supplies have reached the low threshold. The product was set to stop printing when a supply needs to be ordered.
Press the OK button to continue printing until the supply reaches its estimated end of life.
REPLACE SUPPLIES - OVERRIDE IN USE
The product indicates when a supply level is at its estimated end of life. The actual life remaining might be different than the estimation. Have a replacement supply available to install when print quality is no longer acceptable. The supply does not need to be replaced now unless the print quality is no longer acceptable. Once an HP supply has reached its estimated end of life, HP’s premium Protection Warranty on that supply has ended. Printing can continue using override (see REPLACE SUPPLIES menu item).
note: |
Open the SUPPLIES STATUS menu for information about each supply. Press the OK button for detailed information.
REPLACE SUPPLIES - Using black only
You can configure the product to print using only black when the level of a color supply has reached its estimated end of life. However, the color supply might still be able to produce acceptable print quality. To print in color, either replace the color supply or reconfigure the printer by using the REPLACE SUPPLIES menu on the control panel. For more information about the REPLACE SUPPLIES menu, see System setup menu.
The supply life remaining is used to determine if a supply is very low. The supply life remaining is an approximation only and varies depending on the types of documents printed and other factors.
No user input is required for printing to continue in black. To continue printing in color, either replace the supply or reconfigure the printer by using the REPLACE SUPPLIES menu on the control panel. For more information about ordering supplies, see Supplies and accessories. For more information about the REPLACE SUPPLIES menu, see System setup menu.
The toner collection unit has reached its estimated capacity.
Replace the toner collection unit or, if you wish to have the toner collection unit operate past its estimated capacity, reconfigure the printer to use OVERRIDE AT OUT 2 in the REPLACE SUPPLIES menu. For more information about the REPLACE SUPPLIES menu, see System setup menu.
This is not a recommended option because of the risk of overfilling the toner collection unit, which could result in the need to service the product.
The toner collection unit is approaching its estimated capacity.
Order a new toner collection unit now.
You can press the OK button to continue printing. You can continue printing until the continue prompt no longer appears.
Request accepted please wait
The product has accepted a request to print an internal page, but the current job must finish printing before the internal page will print.
Resend Upgrade
The firmware upgrade was not completed successfully.
Attempt upgrade again.
Resetting kit count
You have selected the option to reset the count for a new supply item.
Restoring factory settings
The product is restoring factory settings.
Restoring...
The product is restoring settings. This message is displayed during the execution of a restore action, such as RESTORE COLOR VALUES.
Please wait until the process is complete.
RESTRICTED FROM PRINTING IN COLOR
This message appears when color printing is disabled for the product or when it is disabled for a particular user or print job.
To enable color printing for the product, change the RESTRICT COLOR USE setting in the SYSTEM SETUP menu. See Restrict color printing.
ROM DISK DEVICE FAILURE
To clear press OK
ROM DISK FILE OPERATION FAILED
To clear press OK
ROM DISK FILE SYSTEM IS FULL
To clear press OK
ROM DISK IS WRITE PROTECTED
To clear press OK
Rotating <color> Motor
To exit press
A component test is in progress; the component selected is the <color> cartridge motor.
Rotating Motor
To exit press
The product is executing a component test and the component selected is a motor.
SANITIZING DISK <X>% COMPLETE
Do not power off
The hard disk is being cleaned.
Contact the network administrator.
SIZE MISMATCH IN TRAY XX
The paper in the listed tray does not match the size specified for that tray.
Sleep mode on
The product is in sleep mode. A button press, receipt of printable data, or an error condition will clear this message.
STANDARD TOP BIN FULL
Remove all paper from bin
The output bin is full.
Empty the bin and continue printing.
To change size or type press OK
To accept settings press
This message states the current type and size configuration of the tray.
To change size or type press the OK button. To accept settings press the back arrow
TRAY <X> EMPTY [TYPE] [SIZE]
The specified tray is empty and the current job does not need this tray to print.
Refill the tray at a convenient time.
TRAY <X> OPEN
The specified tray is open or not closed completely.
Close the tray.
TRAY <X> OVERFILLED
Remove excess paper
The tray is filled above the stack-height marking.
Remove enough paper so that the paper stack does not exceed the limit for the tray.
TRAY <X> SIZE = <Size>
The product is set to print on a small paper size that requires the HP postcard media-insert to be installed in this tray.
To use this size paper, install the media insert before loading the paper. See Load trays
TYPE MISMATCH IN TRAY X
The specified tray contains a paper type that does not match the configured type.
The specified tray will not be used until this condition is addressed. Printing can continue from other trays.
UNABLE TO MOPY JOB
The product does not have enough memory to produce multiple original prints of this job. One copy will be printed.
Add more memory to the product. See Install memory.
UNABLE TO STORE JOB
A job cannot be stored because of a memory or configuration problem.
Install additional memory in the product.
Unsupported data on [FS] DIMM in slot x
To clear press OK
The data on the DIMM for the indicated file system is not a type that the product supports. [FS] can be either a ROM or Flash file system.
Replace the DIMM. See Install memory.
UNSUPPORTED DRIVE INSTALLED
A non-supported hard drive has been installed.
Turn off the product, remove the hard drive, and then turn on the product.
USB ACCESSORY ERROR
This message appears when a connected USB accessory draws too much power. When this happens, the ACC port is disabled and printing stops.
Printing can continue. The USB device should be removed.
USB storage <X> initializing
One of the parameters of the USB storage device is initializing.
USB STORAGE <X> IS NOT FUNCTIONAL
A parameter in the USB storage is not working correctly.
USB STORAGE <X> IS REMOVED
A USB storage accessory has been disconnected.
USB STORAGE DEVICE FAILURE
To clear press OK
USB STORAGE FILE OPERATION FAILED
To clear press OK
USB STORAGE FILE SYSTEM IS FULL
To clear press OK
USB STORAGE IS WRITE PROTECTED
To clear press OK
USB STORAGE NOT INITIALIZED
WAIT FOR PRINTER TO REINITIALIZE
This message can appear for a variety of reasons: The RAM DISK settings changed before the product has rebooted. The product is restarting after changing external device modes. The user has exited Diagnostics. A new formatter has been installed with an old engine or a new engine has been installed with an old formatter.
WAITING FOR TRAY <X> TO LIFT
The specified tray is lifting paper for feeding.
WARMING UP
The product is coming out of Sleep mode.
WRONG CARTRIDGE IN <COLOR> SLOT
The indicated slot for a print cartridge contains a cartridge that is not the correct color. From left to right, the print cartridges should be installed in this order:
Remove the print cartridge from that slot, and install a cartridge that is the correct color.
