Support Menu
Support Home
Products
Printer Support
Computer Support
Poly Collaboration Devices
All
Software and Drivers
Diagnostics
Printer Diagonostic Tools
Computer Diagnostic Tools
Windows Support
Print and Scan Doctor
HP PC Hardware Diagnostics
Contact Us
Business Support
Create a new case
Find an existing case
Manage contracts and warranties
Register an account
MyHPSupport Help
Security Bulletins
*Login Required
My HP Account
Support Dashboard
HP Account benefits
1
solution Content
solution Content
HP Compaq Notebook PCs - Unable to Turn On Wi-Fi or Bluetooth
Issue:
The Wireless LAN and Bluetooth devices cannot be turned on. The Wireless Button does respond when pressed.
Solution
First verify that the Wireless Button is not disabled in the BIOS.
Press F10 at the power-on bios screen
Navigate to the Security menu
Choose Device Security
Verify that "Wireless Network Button" is set to enable. If set to disable, change this to enable and press F10 to confirm settings.
Exit the bios from the File menu, Choose Save Changes and Exit.
If the Wireless Button was enabled or changing the setting did not solve the problem follow the next solution.
From the file menu, Choose "Set Defaults"
Press F10 to confirm when prompted
Additional support options
Try one of our automated tools or diagnostics
Ask a question on our HP Support Community page
Get in touch with one of our support agents
Enter a topic to search our knowledge library
What can we help you with?
Search
Need Help?
Try asking HP's Virtual Assistant.
