HP Laptop 15s-eq1147AU Product Specifications
220B4PA
AMD Ryzen™ 3 3250U (2.6 GHz base clock, up to 3.5 GHz max boost clock, 4 MB L3 cache, 2 cores, 4 threads)
8 GB DDR4-2400 MHz RAM (1 x 8 GB)
Video graphics
AMD Radeon™ Graphics
256 GB PCIe® NVMe™ M.2 SSD
15.6" diagonal, FHD (1920 x 1080), IPS, micro-edge, anti-glare, 250 nits, 45% NTSC
Realtek RTL8822CE 802.11a/b/g/n/ac (2x2) Wi-Fi® and Bluetooth® 5 combo
35.85 x 24.2 x 1.79 cm
Starting at 1.7 kg
45 W Smart AC power adapter
3-cell, 41 Wh Li-ion
Battery life mixed usage
Up to 7 hours
HP TrueVision HD Camera with integrated dual array digital microphone
Audio
Dual speakers
Country/Region: Flag South Africa
