note:The following specifications are correct at the time of publication, but they are subject to change.
Model Name
Product Number
M607n
K0Q14A
M607dn
K0Q15A
M608n
K0Q17A
M608dn
K0Q18A
M608x
K0Q19A
M609dn
K0Q21A
M609x
K0Q22A
E60055dn
M0P33A
E60065dn
M0P35A
E60065x
M0P36A
E60075dn
M0P39A
E60075x
M0P40A
Paper handling features
M607n, M608n
M607dn, M608dn, M609dn, E60055dn, E60065dn, E60075dn
M608x, M609x, E60065x, E60075x
Tray 1 (100-sheet capacity)
Tray 2 (550-sheet capacity)
1x550-sheet paper feeder
note: |
Optional
Optional
2,100-sheet high-capacity feeder
note: |
Optional
Optional
Optional
Automatic duplex printing
Not supported
Envelope feeder cassette for printing up to 75 envelopes
Optional
Optional
Optional
Tray 2 extension cover for printing on Legal-size media
HP Stapling Mailbox
note: |
Optional
Optional
Optional
Connectivity features
M607n, M608n
10/100/1000 Ethernet LAN connection with IPv4 and IPv6
Hi-Speed USB 2.0
Easy-access USB port for printing and scanning without a computer and upgrading the firmware
Hardware integration pocket (HIP) for connecting accessory and third-party devices
HP Internal USB Ports
Optional
Optional
Optional
HP Jetdirect 3000w NFC/Wireless Accessory for printing from mobile devices
Optional
Optional
Optional
HP near-field communication (NFC) and Wi-Fi Direct accessory for printing from mobile devices
Optional
Optional
Optional
HP Jetdirect 2900nw Print Server accessory for Wireless connectivity
Optional
Optional
Optional
Print features
M607n, M608n
Prints 52 pages per minute (ppm) on A4 and 55 ppm on letter-size paper
M607n
M607dn, E60055dn
n/a
Prints 61 ppm on A4 and 65 ppm on letter-size paper
M608n
M608dn, E60065dn
M608x, E60065x
Prints 71 ppm on A4 and 75 ppm on letter-size paper
n/a
M609dn, E60075dn
M609x, E60075x
Easy-access USB printing (no computer required)
Other features
M607n, M608n
Memory: 512 MB memory, expandable to 1.5 GB by adding 1 GB DIMM
Memory: HP Secure High-Performance Hard Disk
Optional
Optional
Optional
Security: HP Trusted Platform Module for encrypting all data that passes through the printer
Optional
Optional
Optional
Control panel: Color keypad control panel
Not supported
Control panel: Constant-view color touchscreen
Not supported
Not supported
Print driver (for Windows, or the installer on the web for macOS)
Windows 7, 32-bit and 64-bit
The "HP PCL 6" printer-specific print driver is installed for this operating system as part of the software installation.
Windows 8, 32-bit and 64-bit
Windows 8.1, 32-bit and 64-bit
The "HP PCL-6" V4 printer-specific print driver is installed for this operating system as part of the software installation.
Windows 10, 32-bit and 64-bit
Windows Server 2008 R2, SP 1, 64-bit
The "HP PCL 6" printer-specific print driver is available for download from the printer-support website. Download the driver, and then use the Microsoft Add Printer tool to install it.
Windows Server 2012, 64-bit
The PCL 6 printer-specific print driver is available for download from the printer-support website. Download the driver, and then use the Microsoft Add Printer tool to install it.
Windows Server 2012 R2, 64-bit
Windows Server 2016, 64-bit
Windows Server 2019, 64-bit
macOS 10.13 High Sierra, macOS 10.14 Mojave, macOS 10.15 Catalina
Download HP Easy Start from 123.hp.com/LaserJet, and then use it to install the print driver.
note:Supported operating systems can change.
note:For details on client and server operating systems and for HP UPD driver support for this printer, go to www.hp.com/go/upd. Under Additional information, click the links.
Windows
macOS
note:Update the printer firmware to ensure all mobile printing and ePrint capabilities are supported.
Printer fully closed
Printer fully opened
Dimension
1–Height
380 mm
453 mm
2–Width
431 mm
431 mm
3–Depth
466 mm
1,040 mm
Weight (with toner cartridge)
21.6 kg
21.6 kg
Dimension
1–Height
505 mm
581 mm
2–Width
431 mm
431 mm
3–Depth
466 mm
1,100 mm
27.3 kg
27.3 kg
Accessory fully closed
Accessory fully opened
Dimension
1–Height
148 mm
148 mm
2–Width
426 mm
426 mm
3–Depth
466 mm
790 mm
5.7 kg
5.7 kg
Dimension
Printer and accessory fully closed
Printer and accessory fully opened
Height
505 mm
581 mm
Width
431 mm
431 mm
Depth
466 mm
1,100 mm
27.3 kg
27.3 kg
Dimension
1–Height
341 mm
341 mm
2–Width
426 mm
426 mm
3–Depth
466 mm
864 mm
10.1 kg
10.1 kg
Dimension
Height
698 mm
773 mm
Width
431 mm
431 mm
Depth
466 mm
1,180 mm
31.7 kg
31.7 kg
Dimension
1–Height
148 mm
148 mm
2–Width
426 mm
426 mm
3–Depth
466 mm
790 mm
5.8 kg
5.8 kg
Dimension
Height
505 mm
581 mm
Width
431 mm
431 mm
Depth
466 mm
1,100 mm
27.3 kg
27.3 kg
Dimension
Height
429 mm
429 mm
Width
475 mm
511 mm
Depth
504 mm
614 mm
11.5 kg
11.5 kg
Dimension
Height
775 mm
775 mm
Width
472 mm
608 mm
Depth
466 mm
1,100 mm
33.1 kg
33.1 kg
Printing
Ready
Sleep
Off
780 W
45 W
0.8 W
Less than 0.1 W
note:Power requirements are based on the country/region where the printer is sold.
caution:Do not convert operating voltages. This will damage the printer and void the printer warranty.
Specification
110-volt models
220-volt models
Power requirements1
100 to 127 volts (± 10%)
50/60 Hz (± 3 Hz)
220 to 240 volts (± 6%)
50/60 Hz (± 3 Hz)
Rated current
12 amps
6 amps
note:Acoustic emissions are declared per ISO 9296.
Printer status
Sound power level
Sound pressure level
Ready
Inaudible
Inaudible
Printing
LwAD = < 6.9 Bels (A)
LpAm = 55 dB(A)
Printer status
Sound power level
Ready
Inaudible
Inaudible
Printing
LpAm = 55 dB(A)
Printer status
Sound power level
Ready
Inaudible
Inaudible
Printing
LpAm = 54 dB(A)
Printer status
Sound power level
Ready
Inaudible
Inaudible
Printing
LwAD = < 7.1 Bels (A)
LpAm = 56 dB(A)
Printer status
Sound power level
Ready
Inaudible
Inaudible
Printing
LwAD = < 7.0 Bels (A)
LpAm = 55 dB(A)
Environment
Recommended
Allowed
Temperature
17° to 25°C
10° to 32.5°C
Relative humidity
30% to 70% relative humidity (RH)
10% to 80% RH
