HP mt20 Mobile Thin Client - Specifications
Operating systems
Specification
Preinstalled
HP ThinPro with Smart Zero Core
HP Cloud PC
Microsoft Windows 10 IoT Enterprise 64-bit
Not all features are available in all editions or versions of Windows. Systems might require upgraded and/or separately purchased hardware, drivers, software or BIOS update to take full advantage of Windows functionality. Windows 10 automatic updates are always enabled. ISP fees may apply and additional requirements might apply over time for updates.
In accordance with Microsoft support policy, this product does not support Windows 8 or Windows 7. HP does not support the Windows 8 or Windows 7 operating system on products configured with Intel and AMD 7th generation or later processors, or provide any Windows 8 or Windows 7 drivers.
Processors
Specification
Intel Celeron 3865U
1.8 GHz dual-core
Intel HD graphics
HD content required to view HD images.
Multicore is designed to improve performance of certain software products. Not all customers or software applications necessarily benefit from use of this technology. Performance and clock frequency vary depending on application workload and hardware and software configurations. Intel numbering is not a measurement of higher performance.
Processor speed denotes maximum performance mode; processors run at lower speeds in battery optimization mode.
Graphics
Specification
Integrated (with Celeron processor)
Intel HD graphics
Specification
Internal
35.6 cm (14 in) diagonal HD anti-glare LED-backlit (1366 x 768)
External (display capabilities)
VGA
Port supports resolutions up to 2048 x 1536 at 60 Hz
HDMI
Supports direct connection to high-definition displays with up to 4096 x 2160 at 24 Hz
7-channel audio with 1 cable (cable not included)
Resolutions are dependent upon monitor capability and resolution and color depth settings.
Storage/drives
Specification
Flash memory storage drive
128 GB M.2 2280 flash memory storage drive
For flash memory drives, GB = 1 billion bytes. Actual formatted capacity is less.
Memory
Specification
Standard
DDR4 SODIMMs (transfer rates up to 2133 MT/s)
(2) SODIMM slots supporting dual-channel memory (both slots are customer accessible/upgradable)
Maximized dual-channel performance requires SODIMMs of the same size and speed in both memory slots.
Maximum
Up to 16 GB (2 x 8 GB dual-channel configuration)
Due to the non-industry standard nature of some third-party memory modules, we recommend HP branded memory to ensure compatibility. If memory speeds are mixed, the system performs at the lower memory speed.
Networking/communication
Specification
Wi-Fi (WLAN)1
Intel Dual Band Wireless-AC 3168 Wi-Fi and Bluetooth 4.2 Combo 802.11ac (1x1)
Wired LAN2
Realtek RTL8111HSH Gigabit Ethernet
1Wireless access point and Internet service required and sold separately. Availability of public wireless access points limited. The specifications for the 802.11ac WLAN are draft specifications and are not final. If the final specifications differ from the draft specifications, it might affect the ability of the notebook to communicate with other 802.11ac WLAN devices.
2The term "Gigabit Ethernet" indicates compatibility with IEEE standard 802.3ab for Gigabit Ethernet, and does not connote actual operating speed of 1 Gb/s. For high-speed transmission, connection to a Gigabit Ethernet server and network infrastructure is required.
Audio/multimedia
Specification
Audio
(2) Stereo speakers
Integrated microphone (dual-microphone array when equipped with optional webcam)
Headphone/microphone combo jack
720p HD webcam (included on select models)
Internet access required.
Keyboards/pointing devices/function keys
Specification
HP Premium keyboard
Spill-resistant with drain (thin layer of Mylar film under the keyboard)
101/102-key compatible
Full-pitch key layout
U.S.A. and International key layouts are available
Pointing devices
ClickPad with gestures support
Two-way scroll
Taps enabled as default
Gestures enabled by default in Windows 10 IoT
2-finger scrolling
2-finger zoom (pinch)
OSD (enable/disable)
3-finger tap = Cortana
4-finger tap = Action Center
Gestures disabled by default in Windows 10 IoT
3-finger flicking
2-finger rotating
1-finger vertical scrolling
Momentum motion
Function keys
Function keys
F1 – Sleep
F2 – Blank
F3 – Keyboard backlit toggle
F4 – Display switching
F5 – Brightness down
F6 – Brightness up
F7 – Blank
F8 – Volume down
F9 – Volume up
F10 – Microphone mute
F11 – Blank
F12 – Number lock
Additional keys
ESC – System Information
Separate launch buttons for easy access to wireless on/off and speaker mute.
Software/security
Specification
UEFI
UEFI adheres to NIST SP800-147
HP BIOSphere
Features might vary depending on the configuration.
HP BIOS Protection
Might require a manual recovery step if all copies of the UEFI are compromised or deleted.
UEFI Update via network
Master Boot Record Security
Power On Authentication
Pre-Boot Security
Secure Erase
For the methods outlined in the National Institute of Standards and Technology Special Publication 800-88.
Hybrid Boot
Measure Boot
Secure Boot
HP Value Add software
HP Hotkey Filter
HP Easy Shell
HP USB Port Manager
Manageability
HP Device Manager Agent
HP ThinUpdate
HP BIOS Configuration Utility (BCU)
HP CIK for Microsoft SCCM
Client Security software
Microsoft Defender
Security
Trusted Platform Module (TPM) 2.0
Security lock slot
Pre-boot Authentication
Power
Specification
Power supply1
HP 45 W Smart AC Adapter
HP 45 W 2-prong AC Adapter (Japan only)
HP 65 W Smart AC Adapter
Primary battery2
HP 3-cell Long Life Li-Ion (48 WHr) (up to 15 hrs 30 mins life)
Battery is not replaceable by the customer.
1Availability might vary by country/region.
2Windows 10/MM14 battery life varies depending on various factors including product model, configuration, loaded applications, features, use, wireless functionality, and power management settings. The maximum capacity of the battery naturally decreases with time and usage.
Weight/dimensions
Specification
Weight1
Starting at 1.64 kg (3.62 lbs)
Dimensions (W x D x H)2
34.32 x 23.90 x 2.03 cm (13.51 x 9.41 x 0.80 in)
1Weight varies by configuration and components.
2Height varies depending upon where on the notebook the measurement is made.
Ports/slots
Specification
Ports
(1) USB 3.0; Type A port
(1) USB 2.0; Type A (charging)
(1) USB 3.1 Gen 1;Type-C port
(1) VGA video output
(1) HDMI video output
(1) Headphone/microphone combo jack
(1) AC power interface
(1) RJ-45 Gigabit Ethernet interface
All cables are not included and are sold separately.
Slots
(1) Multi-media reader slot (SD, SDHC, and SDXC supported)
Country/Region: Flag South Africa
