how to print on hp printer, how to scan on hp printer, how to fax from hp printer
 Sign In  /  Register
Welcome,
Sign Out
My Account
Dashboard
Dashboard FAQ
  • Support Home
  • Products
    • Printer Support
    • Computer Support
    • Poly Collaboration Devices
    • All
  • Software and Drivers
  • Diagnostics
    • Printer Diagonostic Tools
    • Computer Diagnostic Tools
    • Windows 10 Support
    • Print and Scan Doctor
  • Contact Us
  • Business Support
    • Create a new case
    • Find an existing case
    • Manage contracts and warranties
    • Register an account
    • MyHPSupport Help
    • Security Bulletins
    • Login Required
  • My HP Account
    • My HP Dashboard
    • HP Account benefits
How to Print, Scan or Fax on your HP Printer
  • How to Print
  • How to Scan
  • How to Fax
  • How to Print
  • How to Scan
  • How to Fax
Viewing content for | switch to
How to Print
How to Print (Windows)
You can learn how to print from a USB or wirelessly-connected HP printer by following the steps below.
  1. Select the file you want to print and open the file so it appears on your computer screen.
  2. Press the Ctrl and P buttons on your keyboard at the same time.
  3. Once the printing pop-up menu appears on your computer screen, select the printer you intend to send the job to.
    • If the printer is not connected, get help setting it up through the  HP Printers - USB Printer Setup
    • For wireless printer setup and connection, get help  connecting the printer wirelessly
  4. If needed, modify your print settings. This step is optional.
  5. Click the Print button on screen to send the job into the printer print queue and wait for the job to complete.
Learn more about how to print and troubleshooting
how to print photos image
HP Printers - How to Print Photos (Windows)
Print pictures from your Windows computer to an HP printer.
Learn more
Learn more about how to print envelopes
HP Printers - Printing Envelopes (Windows)
Load and print envelopes with an HP printer and a Windows computer.
Learn more
Learn more about how to cancel a print job
HP Printers - Cancel a Print Job
Cancel a print job that you want to stop or that has become stuck in queue.
Learn more
how to print from iPhone image
HP Printers - Printing from an iPhone, iPad, or iPod Touch
Learn how to print from your iPad, iPhone, iPod touch to an HP wireless printer using Apple AirPrint.
Learn more
How to Print
How to Print (Mac)
  2. Press the Command (⌘) and P on your keyboard at the same time.
    • If the printer is not connected, get help setting it up through the document HP Printers - USB Printer Setup (Mac)
HP Printers - How to Print Photos (Mac)
Print pictures from your Mac computer to an HP printer.
Learn more
how to duplex print image
HP Printers - How to Print on Both Sides of the Paper (Duplex) (Mac)
Learn how to print on both sides of the paper, both with an automatic duplexer and manually, for all HP printers on a Mac computer.
Learn more
how to print black only image
HP Inkjet Printers - Printing with Black Ink Only (Mac)
Learn how to print black and white or grayscale printouts from a Mac computer.
Learn more
Learn more
HP Printers - Printing Envelopes (Mac)
Load and print envelopes with an HP printer and Mac computer.
Learn more
Learn more
Facing problem with your printer?
HP Print and Scan Doctor
Download and run this free tool to resolve common printing issues.
Learn how to download and use the HP Print Scan Doctor
Printer Offline
Printer offline or an offline message displays on the computer, and the printer does not print.
Learn how to resolve this issue
HP Virtual Agent
Use our HP’s automated Virtual Agent to try and find a resolution for your issue.
Printer Offline
Print Job stuck in Queue
The printer cannot print from a computer because a print job is stuck in the Mac print queue.
HP Virtual Agent
CHAT NOW
How to Scan
How to Scan on a Windows Computer
You can learn how to scan documents or photos from a USB or wirelessly-connected multifunction HP printer to a Windows computer by using the steps below. If the printer is not connected, get help setting it up through the USB Printer Setup for HP Printers document.
For wireless printer setup and connection, get help connecting the printer wirelessly.
  1. Software is required to scan a document. Make sure the latest Full Feature Software and Drivers for the printer is downloaded and installed. Start by going to Customer Support  Software and Driver Downloads
  2. Load the item on the scanner glass or in the automatic document feeder (ADF), depending on your printer type and features.
Using Scanner Glass
Lift the scanner lid and load the item to scan on the scanner glass.
Place the item print side down on the scanner glass, and then position it according to the engraved guides along the edge of the glass (usually on the right-front corner or left-front corner).
Using Automatic Document Feeder (ADF)
Place the item print into the document feeder tray. The print side faces up, and the top edge goes into the tray first.
Slide the item into the ADF until you hear a tone or see a message on the control panel display indicating that the loaded item is detected. Adjust the paper guides to fit the item.
  1. Depending on the printer, open HP Scan (printers released 2011 and later) or HP Solution Center (printers released 2010 and earlier).
    • Open HP Scan software and follow the steps in the video:
      Scanning from an HP Printer in Windows with HP Scan.
    • Open HP Solution Center software and follow the on-screen prompts to scan.
  2. Scan the file and save to the desired destination on the computer.
    • In HP Scan you can change the scan destination folder by clicking on Advanced Settings or More.
    • In HP Solution Center you can change the scan destination folder by clicking on Save to File Save Options.
How to Scan
How to Scan on a Mac
You can learn how to scan documents or photos from a USB or wirelessly-connected multifunction HP printer to a Mac computer by using the steps below. If the printer is not connected, get help setting it up through the USB Printer Setup for HP Printers (Mac) document.
  1. Software is required to scan a document. Make sure the latest Full Feature Software and Drivers for the printer is downloaded and installed. Start by going to Customer Support  Software and Driver Downloads .
  2. Download HP Easy Scan   from the App Store.
    • Open HP Easy Scan and follow the steps in this video:
      Scanning from an HP Printer to macOS with HP Easy Scan.
  3. Load the item on the scanner glass or in the automatic document feeder (ADF), depending on your printer type and features.
Using Scanner Glass
  1. Click Scan. Once the scan is complete, click Done or Scan Next Item.
  2. Save to the desired location on the Mac by clicking Send, then Folder, and select where to save the scanned file.
Download and run this free tool to resolve common scanning issues.
HP Virtual Agent
Printer Offline
HP Virtual Agent
CHAT NOW
Other Resources
  • HP Printers - How to Scan
  • HP Printers - Install and Use the HP Smart App (Android, Apple iOS, iPadOS)
How to fax
HP Printers - Sending and receiving fax
You can learn how to fax from a fax-enabled HP printer by following the steps below.
  1. Ensure the printer is connected and set up properly. Learn how to test the fax machine by following the steps within the document  HP Printers and Fax Machines - Test Fax Setup with the HP Fax Test Service
  2. Load the sheets you are intending to fax into the input tray and adjust the width guides so that they rest against the edges of the paper. The printer should indicate whether the printed side of the page(s) should face up or down.
  3. For multifunction HP printers, there may be an option to select Fax. Complete this step before moving on.
  4. If needed, modify the fax settings. This step is optional.
  5. Dial the fax number you are wanting to send the fax to. Be sure to include any dial codes and extensions necessary to route the call correctly.
  6. Press Start, Send, Go, or a start fax-equivalent button.
Other Resources
  • HP Printers and Fax Machines - How to Fax
Logo HP
Sélectionnez le type d'inscription
Comptes personnels
  • Enregistrez vos appareils personnels et vos préférences
  • Accès facile aux ressources de support
Comptes pros/informaticens
  • Gérer les contrats et les garanties pour votre entreprise
  • Soumettre et gérer des cas de soutien
Politique de confidentialité © Copyright 2020 HP Development Company, L.P.
Country/Region: Flag
hp-logo
Select a location
Americas
  • América Central
  • Argentina
  • Bolivia
  • Brasil
  • Canada
  • Canada - Français
  • Caribbean
  • Chile
  • Colombia
  • Ecuador
  • México
  • Paraguay
  • Perú
  • Puerto Rico
  • United States
  • Uruguay
  • Venezuela
Europe, Middle East, Africa
  • Africa
  • Afrique
  • Беларусь
  • België
  • Belgique
  • Bulgaria
  • Česká republika
  • Croatia
  • Danmark
  • Deutschland
  • Estonia
  • España
  • France
  • Ελλάδα
  • Ireland
  • ישראל
  • Italia
  • Казахстан
  • Latvia
  • Lithuania
  • Magyarország
  • Middle East
  • العربية
  • Nederland
  • Norge
  • Österreich
  • Polska
  • Portugal
  • Romania
  • Россия
  • Schweiz
  • Suisse
  • Serbia
  • Slovakia
  • Slovenia
  • South Africa
  • Suomi
  • Sverige
  • Türkiye
  • United Kingdom
  • Украина
  • Bosna i Hercegovina
Asia Pacific and Oceania
  • Australia
  • 中国
  • 中國香港
  • Hong Kong SAR
  • Indonesia
  • India
  • 日本
  • 한국
  • Malaysia
  • New Zealand
  • Philippines
  • Singapore
  • 台灣地區
  • Thailand
  • ไทย
  • Vietnam
