    Apache Log4j Update
HP Web Jetadmin - Import Device Groups and Policy Associations
You can import device groups and policy associations from an XML file. The format of the XML file you import must match the format of the XML file that was created when the device groups were exported.
Important:
If the device groups contain policies, you must import all the device configuration templates before you import the device groups.
To import the device groups and any existing policy associations, perform the following steps:
  1. In the Device Management navigation pane, right-click Groups, and then click Import groups. The Import Groups wizard opens.
  2. On the Select options page, click Browse.
  3. In the Open window, browse to and select the file to import, and then click Open.
  4. To import devices groups that are a subgroup of an existing device group, click the ... button, and then select the parent device group from the list.
  5. Click Next. The Confirm page opens.
  6. Verify that the information is correct, and then click Import Group.
  7. On the Results page, click Done.
