HP LaserJet MFP M630 - Removal and replacement: Formatter
This document provides the procedures to remove and replace the formatter.
Mean time to repair: 10 minutes
Service level: Intermediate
To replace the formatter, remove the hard-disk drive (HDD) or solid-state memory (SSM) storage device, the DIMM, and the fax printed-circuit assembly (PCA) (if installed) from the defective formatter and then install them on the replacement formatter.
Before performing service
Turn the printer power off
  • Disconnect the power cable.
    Warning:
    To avoid damage to the printer, turn the printer off, wait 30 seconds, and then remove the power cord before attempting to service the printer.
CAUTION:
This part contains components that are electrostatic discharge (ESD) sensitive. To reduce the possibility of ESD damage, always touch the sheet-metal chassis to ground yourself before touching an ESD sensitive part.
Important:
Do not replace the formatter, DC controller, and hard-disk drive simultaneously during a single printer servicing. Doing so might cause the printer to become unstable or inoperable.
Use the table below to identify the correct part number for your printer, and then go to http://h20141.www2.hp.com/hpparts to order the part.
Part information
Formatter kit part numbers
B3G85-67901
Formatter kit with instruction guide
B3G85-67902 (China/India)
Formatter kit with instruction guide (China/India only)
Required tools
  • No special tools are required to install this kit.
After performing service
Turn the printer power on
  • Connect the power cable.
    Tip:
    If the product does not initialize when the power is turned on, make sure that the memory DIMM is correctly installed.
    To verify that the formatter is correctly installed, observe the following functions of the LEDs on the formatter:
    • The heartbeat LED (callout 1) illuminates if the formatter is functioning correctly.
      • While the product is initializing, the heartbeat LED illuminates solid red for about one second, and then turns solid green for about twenty seconds.
      • After the initialization sequence is complete, the heartbeat LED blinks continuously if the printer is functioning correctly.
    • The connectivity LED (callout 2) indicates that the formatter is completely seated. It illuminates green when the product power is turned on and stays green if the formatter is properly seated.
    If the LEDs do not correctly function, turn the product power off, remove the formatter, and then reinstall it (make sure that the formatter is fully seated before tightening the thumbscrews).
    Verify that the formatter is functioning
    Check formatter LEDs
Post service test
Print a configuration page to make sure that the printer is functioning correctly.
Remove the formatter
Follow these steps to remove the formatter.
  1. Loosen the two thumbscrews on the formatter.
  2. Slide the formatter straight out of the product to remove it.
Identify the storage type device
Follow these steps to identify the storage type device.
  1. Hard-disk drive (HDD). See .
    Hard-disk drive
    hard-disk drive
  2. Solid-state memory (SSM). See .
    Solid-state memory
    Solid-state memory
Remove the HDD
Follow these steps to remove the HDD.
If the printer has a solid-state memory, skip this step.
CAUTION:
ESD sensitive assembly.
  1. Push and hold the locking lever (callout 1) toward the HDD to release it, and then slide the black plastic HDD case in the direction of the arrows (callout 2) to remove the HDD.
    Remove the HDD
    Remove the HDD
Remove the SSM
Follow these steps to remove the SSM.
If the printer has a hard-disk drive, skip this step.
CAUTION:
  1. Rotate the retainer clip to release it.
    Release the clip
    Release the clip
  2. Lift the retainer clip up to remove it.
    Remove the clip
    Remove the clip
  3. Slide the SSM away from the connector to remove it.
    Remove the SSM
    Remove the SSM
Remove the DIMM
Follow these steps to remove the DIMM.
CAUTION:
  1. Release two clips.
    Release two clips
    Release two clips
  2. Rotate the DIMM upward (callout 1), and then remove it (callout 2).
    Remove the DIMM
    Remove the DIMM
Remove the fax PCA
Follow these steps to remove the fax PCA.
CAUTION:
Note:
If the product does not have a fax PCA, go to the next step.
  1. Locate the fax PCA that is installed on the formatter.
    Locate the fax PCA
    Locate the fax PCA
  2. Rotate the connector end (away from the phone port) of the fax PCA up and away from the formatter to release it.
    Release the connector end of the fax PCA
    Release the fax PCA
  3. Carefully remove the fax PCA from the formatter bracket.
    Note:
    Set this part aside. It will be installed on the replacement formatter.
    Remove the fax PCA
    Remove the fax PCA
Unpack the replacement assembly
Follow these steps to unpack the replacement assembly.
  1. Dispose of the defective part.
    Note:
    http://www8.hp.com/us/en/hp-information/environment/product-recycling.html
  2. Unpack the replacement part from the packaging.
    CAUTION:
    Some parts are sensitive to electrostatic discharge (ESD). Always perform service work at an ESD-protected workstation or mat. If an ESD workstation or mat is not available, touch the sheet-metal chassis to provide a static ground before touching an ESD-sensitive assembly. Protect the ESD-sensitive assemblies by placing them in ESD pouches when they are out of the printer.
    Important:
    Make sure that all of the shipping materials (for example shipping tape) are removed from the replacement part prior to installation.
    Note:
    If the replacement part is a roller or pad, avoid touching the spongy part of it. Skin oils on the roller or pad can cause paper pickup and/or print-quality problems. HP recommends using disposable gloves when handling rollers or pads or washing your hands before touching rollers or pads.
  3. To install an assembly, reverse the removal steps.
    Note:
    When applicable, special installation instructions are provided for an assembly at the end of the removal procedure. Always completely read the removal instructions and follow all special installation instructions.
Install the fax PCA
Follow these steps to install the fax PCA.
CAUTION:
Note:
  1. Insert the fax port of the fax PCA into the holder on the formatter tray.
    Insert the fax port into the holder
  2. Rotate the connector end of the fax PCA in the direction of the arrow to install it.
    Install the fax PCA
    Install the fax PCA
Install the DIMM
Follow these steps to install the DIMM.
CAUTION:
  1. Carefully insert the DIMM at an angle into the holder on the formatter.
    Note:
    Position the DIMM so that the slot in the DIMM is aligned with the tab in the holder.
    Insert the DIMM into the holder
    Align the DIMM notch with the connector tab
  2. Rotate the DIMM in the direction of the arrow to install it.
    Install the DIMM
    Install the DIMM
  3. When the DIMM is installed make sure that the retaining clips on the right and left sides of the DIMM snap into place.
    Make sure that the retaining clips snap into place
    Check the DIMM installation
Install the HDD or SSM
Follow these steps to install the HDD or SSM.
CAUTION:
  1. To install the HDD, do the following steps:
    1. If foam pads are installed on the backside of the HDD, press down on the connector-side corners of the HDD and on the locking lever to compress the foam.
      CAUTION:
      Do not press down on the center of the HDD.
      Note:
      If there are no foam pads installed on the backside of the HDD, skip this step.
      Press down on the HDD
    2. If foam pads are installed on the backside of the HDD, press down on the connector-side corners of the HDD and on the locking lever to compress the foam.
      CAUTION:
      Note:
    3. Slide the HDD into the connector on the formatter.
      Note:
      If foam pads are installed on the backside of the HDD, make sure that they are compressed enough to allow the HDD to easily slide into the connector, and that the locking lever fits into the slot on the formatter.
      Install the black plastic HDD case
      Install the HDD
    4. When correctly installed, the HDD locking lever (callout 1) and the connector (callout 2) are securely fastened. Make sure that locking lever prevents the HDD from moving, and that the HDD is fully seated in the connector.
      Make sure that the HDD is flat against the formatter
      Check the HDD installation
  2. To install the SSM, do the following steps:
    1. Slide the SSM in the direction of the arrow to install it.
      Install the SSM
      Install the SSM
    2. Position the retainer clip (callout 1) in the slot (callout 2).
      Install the retainer clip
    3. Rotate the retainer clip to lock it.
      Rotate the retainer
      Lock the retainer clip
Install the formatter
Follow these steps to install the formatter.
CAUTION:
  1. Align the formatter with the guides at the top and bottom of the formatter cage and push the formatter into the slot until it is fully seated.
    Align the formatter with the guides and push the formatter into the slot
  2. Finger-tighten the two thumbscrews.
    Tighten the two thumbscrews
    Tighten two thumbscrews
