HP PageWide Enterprise Color 765 and MFP 780/785 - Install accessory: Foreign interface harness (FIH)
This document provides the procedures to install the foreign interface harness (FIH).
When applicable, special installation instructions are provided for an assembly at the end of the removal procedure. Always completely read the removal instructions and follow all special installation instructions.
Mean time to repair: 5 minutes
Service level: Basic
Before performing service
  • Disconnect the power cable.
      warning:
Use the table below to identify the correct part number for your printer. To order the part, go to www.hp.com/buy/parts
Foreign interface harness (FIH) part number
B5L31-67902
Required tools
  • No special tools are needed to remove or install this assembly.
After performing service
Turn the printer power on
  • Connect the power cable.
Post service test
No post service test is available for this assembly.
  1. Install the foreign interface harness (FIH).
    1. Locate the USB port on the printer, and then plug the USB end of the FIH cable into the printer USB port.
      Figure : Plug the FIH cable into the printer USB port
