HP Color LaserJet Enterprise MFP M681, M682 - Removal and replacement: Staple cartridge and carrier (Flow M681z, Flow M682z)
This document provides the procedures to remove and replace the staple cartridge and carrier.
Mean time to repair: 5 minutes
Service level: Basic
When applicable, special installation instructions are provided for an assembly at the end of the removal procedure. Always completely read the removal instructions and follow all special installation instructions.
Before performing service
  • Disconnect the power cable.
      warning:
Use the table below to identify the correct part number for your printer. To order the part, go to www.hp.com/buy/parts
Staple cartridge and carrier part numbers
J8J96A
Staple cartridge refill
B5L46-60102
Staple carrier
Required tools
  • No special tools are needed to remove or install this assembly.
After performing service
Turn the printer power on
  • Connect the power cable.
Post service test
Print a multiple page document and request that it is stapled. Verify that the document is correctly stapled.
  1. Remove the staple cartridge and carrier.
    1. Open the staple-cartridge door.
      Opening the staple-cartridge door disables the stapler.
    2. Grasp the colored tab on the staple cartridge, and then pull the staple cartridge straight out.
    3. Press the end of the staple cartridge refill closest to the green handle down to release it (callout 1), and then rotate the refill away from the carrier (callout 2) to remove it.
      Figure : Release the staple cartridge refill
  2. Unpack the replacement assembly.
    1. Dispose of the defective part.
    2. Unpack the replacement part from the packaging.
      Some parts are sensitive to electrostatic discharge (ESD). Always perform service work at an ESD-protected workstation or mat. If an ESD workstation or mat is not available, touch the sheet-metal chassis to provide a static ground before touching an ESD-sensitive assembly. Protect the ESD-sensitive assemblies by placing them in ESD pouches when they are out of the printer.
      If the replacement part is a roller or pad, avoid touching the spongy part of it. Skin oils on the roller or pad can cause paper pickup and/or print-quality problems. HP recommends using disposable gloves when handling rollers or pads or washing your hands before touching rollers or pads.
      Make sure that all of the shipping materials (for example shipping tape) are removed from the replacement part prior to installation.
    3. To install an assembly, reverse the removal steps.
  3. Install the staple cartridge.
    1. Position the tab on the staple cartridge refill into the slot in the carrier.
      Figure : Position the staple cartridge refill
    2. Rotate the staple cartridge refill toward the carrier to install it.
      Figure : Install the staple cartridge refill
    3. Insert the staple cartridge into the stapler and press the colored handle toward the printer until it snaps into place.
    4. Close the staple-cartridge door.
Country: Flag Vietnam
