Removal and replacement: Control panel (X555)
This document provides instructions about removing and replacing the control panel.
Mean time to repair:10 minutes
Service level:Basic
Before performing service
Turn the printer power off
  • Disconnect the power cable.
      warning:
    To avoid damage to the printer, turn the printer off, wait 30 seconds, and then remove the power cord before attempting to service the printer.
  • Disconnect either the USB cable or the network ethernet cable.
Use the table below to identify the correct part number for your printer. To order the part, go to www.hp.com/buy/parts.
Control panel kit part number
5851-5950
Control panel kit with instruction guide
Required tools
No special tools are required to install this kit.
After performing service
Turn the printer power on
  • Reconnect either the USB cable or the network cable.
  • Connect the power cable.
Post service test
Print a configuration page to make sure that the printer is functioning correctly.
  1. Remove the control panel.
    1. Tilt the control panel away from the product.
      Figure : Remove the control panel — X555 models (1 of 4)
    2. Remove the access cover behind the control panel.
      Figure : Remove the control panel — X555 models (2 of 4)
    3. Turn the lock lever counterclockwise to release it.
      Figure : Remove the control panel — X555 models (3 of 4)
    4. Lift the left end of the control panel up, and then disconnect three connectors (callout 1) and the ground wire (callout 2).
      Figure : Remove the control panel — X555 models (4 of 4)
  2. Unpack the replacement control panel.
    1. Dispose of the defective part.
    2. Unpack the replacement part from the packaging.
      Some parts are sensitive to electrostatic discharge (ESD). Always perform service work at an ESD-protected workstation or mat. If an ESD workstation or mat is not available, touch the sheet-metal chassis to provide a static ground before touching an ESD-sensitive assembly. Protect the ESD-sensitive assemblies by placing them in ESD pouches when they are out of the printer.
      If the replacement part is a roller or pad, avoid touching the spongy part of it. Skin oils on the roller or pad can cause paper pickup and/or print-quality problems. HP recommends using disposable gloves when handling rollers or pads or washing your hands or before touching rollers or pads.
      Make sure that all of the shipping materials (for example shipping tape) are removed from the replacement part prior to installation.
  3. Install the control panel.
    1. Install the control panel and connect three connectors (callout 1), and then connect the ground wire (callout 2).
      Figure : Install the control panel — X555 models (1 of 3)
    2. Turn the lock lever clockwise to secure it.
      Figure : Install the control panel — X555 models (2 of 3)
    3. Install the access cover behind the control panel.
      Figure : Install the control panel — X555 models (3 of 3)
