HP PageWide Enterprise Color 556, MFP 586 - Removal and replacement: Output bin
This document provides the procedures to remove and replace the output bin.
Mean time to repair: 3 minutes
Service level: Basic
Before performing service
Turn the printer power off
  • Disconnect the power cable.
      warning:
Use the table below to identify the correct part number for your printer. To order the part, go to www.hp.com/buy/parts.
Output bin kit part number
G1W39-67944
Output bin with instruction guide
Required tools
  • No special tools are needed to remove or install these assemblies.
After performing service
Turn the printer power on
  • Connect the power cable.
Post service test
Send a color print job to the printer.
  1. Remove the right cover (outer).
    1. Pull out on the top corners of the right cover to release the top edge of the cover.
      Open the cartridge door to make removing the cover easier.
      Figure : Release the right cover (outer)
    2. Slide the cover up and away from the printer to remove it.
      Figure : Remove the right cover (outer)
  2. Remove the output bin.
    1. Slightly slide the output bin to the right, and then lift up on it to remove it.
      Figure : Remove the output bin
  3. Unpack the replacement assembly.
    1. Dispose of the defective part.
    2. Unpack the replacement part from the packaging.
      If the replacement part is a roller or pad, avoid touching the spongy part of it. Skin oils on the roller or pad can cause paper pickup and/or print-quality problems. HP recommends using disposable gloves when handling rollers or pads or washing your hands or before touching rollers or pads.
      Make sure that all of the shipping materials (for example shipping tape) are removed from the replacement part prior to installation.
  4. Install the output bin.
    1. Position the replacement output bin on the printer. Align the tabs (callout 1) on the output bin with the slots (callout 2) in the top of the printer.
      Figure : Align the tabs and slots
    2. Slide the output bin toward the printer to install it.
      Make sure that the output bin is completely installed against the printer with no gaps in between.
      Figure : Install the output bin
  5. Install the right cover (outer).
    1. Position the bottom edge of the cover on the printer.
      Figure : Position the right cover (outer) on the printer
    2. Push in along the top edge of the right cover (outer) to install it.
      Figure : Install the right cover (outer)
