HP LaserJet Enterprise M607, M608, M609 and HP LaserJet Enterprise MFP M631, M632, M633 - Install: Internal USB ports/AA module
This document provides the procedures to install the internal USB ports/AA module.
Mean time to repair: 5 minutes
Service level: Basic
When applicable, special installation instructions are provided for an assembly at the end of the removal procedure. Always completely read the removal instructions and follow all special installation instructions.
Before performing service
  • Disconnect the power cable.
      warning:
Use the table below to identify the correct part number for your printer. To order the part, go to www.hp.com/buy/parts
Internal USB ports/AA module part number
B5L28-67902
Two internal USB ports kit
Required tools
  • No special tools are needed to remove or install this assembly.
After performing service
Turn the printer power on
  • Connect the power cable.
Post service test
No post service test is available for this assembly.
  1. Remove the formatter cover.
    1. To remove the formatter cover, do the following:
      • On the formatter cover, release two thumb screws (callout 1).
      • Slide the formatter cover in the direction indicated by the arrow (callout 2) and remove it.
      Figure : Release two thumb screws and remove the formatter cover
  2. Install the USB ports/AA module.
    1. M607/M608/M609 printers: From the internal USB ports/AA module accessory kit, obtain the following items:
      • The small PCA board.
      • The PCA mounting cradle.
      • The double-cable (F2A76-60115).
      Figure : Accesory kit items that are required
    2. Locate the empty space in the upper right corner where the internal USB ports/AA module will be installed.
      Figure : Locate the space for installing the internal USB ports/AA module
    3. Do the following:
      • Hold the small PCA and the PCA mounting cradle in the correct orientation.
      • Align the top and bottom cutouts of the PCA on the tabs of the PCA mounting cradle.
      • Secure the small PCA on the PCA mounting cradle until it snaps in place.
      Figure : Mount the PCA on the PCA mounting cradle and snap it in place
    4. Attach the large white connector end of the double cable to the large connector receptacle on the small PCA board.
      Figure : Attach the large white connector to the PCA
    5. Do the following:
      • Hold the small PCA attached to the PCA mounting cradle in the correct orientation, with the attached cable at the bottom.
      • In the upper right corner of the formatter cage area, locate the upper and lower sheet metal hooks.
      • Slide the assembly and mount it so that the upper and lower tabs of the PCA mounting cradle slide into the sheet metal hooks.
      Figure : Mount the assembly on the sheet metal hooks
    6. On the formatter, disconnect the USB cable indicated by the arrow.
      Figure : Disconnect one formatter USB cable
    7. Connect the USB cable (disconnected from the formatter) to the USB connector on the small PCA as indicated by the arrows.
      The USB connector on the small PCA is to the left of where the white connector of the double-cable is installed.
      Figure : Connect the formatter USB cable to the small PCA
    8. Connect the USB cable of the double-cable attached to the small PCA, to the USB connector on the formatter as indicated by the arrow.
      Figure : Connect the small PCA USB cable to the formatter USB connector
    9. Connect the small white connector of the double-cable attached to the small PCA, to the matching connector near the upper right edge of the formatter as indicated by the arrow.
      Figure : Connect the small white connector from the small PCA to the formatter
  3. Install the formatter cover.
    1. Slide the formatter cover onto the printer in the direction indicated by the arrow (callout 1), and then tighten two thumb screws (callout 2).
      The image shown is for the M631/M632/M633 printers, however the install process is the same for M607/M608/M609 printers.
      Figure : Slide on the formatter cover and tighten two thumb screws
Country: Flag Vietnam
